Hi All, I want to share with you and do so with permission the making of draw knife handles by John Aniano. If you'll recall I had fixed up a plane for John a while back, in return he made up a pair of handles for my draw knife (that he also had found for me ). I feel very lucky to be the recipient of such beautiful and masterfully done work and very happy to share the process here:
These handles are for a through tang, and are capped on the back. The draw knife is 1830-'s to 1860's hand made with a beautiful lamination line.
It starts innocently enough with a pair of fittings from the home center.
John then found this dapping block, and worked a sheet of brass into the required shape for the back of the handle
One tang was to short and to thin to be drawn out, so John extended the tang with silver solder over a scarf joint.
A material was chosen (pernambuco), fitted to the ferrules and then fitted to the tangs. They were rough turned at this stage.
John then details the top of the ferrule, each individually fitted to the tang.
John then finished turning the handles using a metal working chuck and a center of his own making. First to work the bottom end of the handle.
Then the remainder.
The handles are finish turned, then smoothed and finished. Next they're reapplied to the tangs.
Next the ends are peened.
Now completed and ready for use.
I hope that you enjoy following along. I do intend to post up a more detailed version of this for the blog, but thought I would share here first.
A drawknife is a special tool. Some woodworkers never find a need for one. If you need one however,having a well built,sharp tool on hand is a delight. I have several and use them constantly. I think you will enjoy that tool for years. Maybe I will rehandle my Weatherbees. Thanks for posting.---Jack
Great writeup, Brian; wonderful work, John. The handles and brass work look terrific. I would not have thought of the scarf joint/silver solder fix--great idea!
Thank you Brian. I have a draw knife that was my grandfathers (he passed in 1975, when I was in high school) that is missing a handle. I think this is just what I need!
Re: Draw Knife Handles - Just the Facts Maam... *LINK*
John Aniano in Central NJ
Hi Brian,
First, thanks for posting this. I thought I'd just add a few more images and details to round out the posting...
The drawknife was made by Joseph Kolp in Cincinnati, around 1845 according to the Directory of American Toolmakers (DAT).
Both tangs were too short for ~6" long handles, so I extended them with the silver solder method. In retrospect, I should have used mild steel for the extensions instead of O-1 steel - it would have been easier to pein the tang ends...
The wood is pernambuco, but Mexican Pernambuco aka Chakta Viga (Coulteria platyloba). Too weak and not dense enough to make instrument bows, but great for handles.
The handle design is inspired from a mid 19th century firmer gouge I own, shown at the far right. I've copied/adapted it many times including a garden trowel handle in purple heart...
The domed ferrules are threaded onto the wood and epoxied into place.
I used my South Bend metal lathe for this project because I recently acquired a Beall ER-50 collet "Big Chuck" which seemed well suited for this job. I would need to mount and remount the handles multiple times as the work progressed. The Beall chucks (I have both the ER-32 and the ER-50) are wonderful tools!!
Because a 1-1/4" ER (Extended Range) collet chuck was available, I turned cylinders at both ends of the handle blanks. The final shaping was done by using a 1" collet and holding the finished brass domed ferrule, with paper in between to protect the finish.
Although mounted onto a metal lathe, I did do much of the turning with hand tools including my favorite 3-point tool, a bit of a "cheater" lathe tool. Can use as a skew as well as a scraper. Used it to cut the bead and do the three decorative marks as well a to define the recess for the brass endcaps. Used pencil lead marks on the inside of the cap, put it in place with the work spinning and where it transferred the lead, I would remove the wood high spots until all fitted closely. Sort of like chalk fitting but using pencil. I cleaned the wood and metal well before epoxying the caps in place.
All in all, a fun project and more challenging than I first thought!
After first trying ~18 year old ShellacWax friction polish, which failed to dry (I wonder why?) I made up fresh friction polish. From a recipe on the web: two parts of freshly mixed, dewaxed 1.5 pound cut shellac to one part commercial "boiled" linseed oil. Applied with a cloth while the work is spun on the lathe. Three or four coats total.
