Hide glue: What consistency is best?
Wiley Horne--So. Calif.
Hi all,
Some practical and useful technical points were made on hot hide glue in an earlier thread. One of them that struck me was that 192g glue has a longer work time (lower gel temperature) than I had imagined.
The amount of work time you have can be critical in deciding whether to use hot hide or room temperature liquid.
I seem to recall a remark made by Patrick Edwards, known for marquetry, where he is talking in a video about the consistency of the hot glue. He was saying to use a thinner consistency than you sometimes see recommended, along the lines of "you don't want the glue to get slow off the brush, because it's the water that's carrying the heat."
Question: For those who use hot hide, how do you gauge the consistency? I have seen recommendations that you want an unbroken column of flow off the brush, versus others who favor faster drops or slower drops. Or does it all depend on the situation?
The consistency you use seems to affect work time (time til gel), and I'm assuming the starting point is ~140F hot glue.
Thanks, Wiley
Re: Hide glue: What consistency is best?
TM Stock
I have little experience with traditional hammer veneering, so defer on the technical aspects, but suggest that the warmer the work and the lower the gram strength, the greater the working time. In my limited experience with the technique, the thicker the glue, the more tenacious the tack, but the shorter the working time. I prefer hide which shows about the same consistency as honey at about the same temperature, and is described by many as - no surprise - the consistency of hot honey.
Also note that fresh hide is easily melted with heat alone, so hide may be brushed onto two surfaces to be joined, allowed to cool, joined, then heated to bond. This does not work for edge joining, but for veneer work and thin plates does pretty well.
Another consideration is to warm the glue-soaked surface with a good heat gun or heat lamp...we have several in the shop for warming bridges for saddle removal, but they work as well on small surfaces. On the one Jefferson desk I did with sawn veneer, this was the approach taken and it worked well enough.
Don Stephan
This question is one I have always struggled with - how to gauge from day to day (sometimes there is a week or two interval) if the consistency is the same.
Especially in cooler weather I will get out my large lazy susan, stack the boards with spacers, and spend several minutes trying to warm the edges to be glued with hot hide glue, using a hot air gun.
Dennis
Experience will be your best teacher,
a starting point of 2 parts water to 1 part glue, (heat to 140° for an hour) then the run/drip off a brush is one test, I add water till the thread just starts to break into drops.
Test the tack between thumb, and forefinger, and watch the strands of glue, learn the feel, time, and the look. Experiment with different consistentcies, with both tests, also put a drop on different types of wood, and observe.
I use different consistency of glue, for differing situations, the temperature can be increased (slightly) to make the glue run thinner without weakening, but this will shorten pot life. Damaged or old glue feels snotty, or rubbery, when tack testing with thumb and forefinger.
On thin pieces, you can balance moisture content by dampening with water to reduce curl, but be careful, too much can weaken the joint, this is true of cleanup as well. It is often better to wait for the glue to gel, and remove it mechanically, than to dissolve with water.
Thank you, Todd. More heat seems to be the most practical approach, as you did with your Jefferson lap desk (I think I remember it!). Even with the reheat method, you have to get a lot of heat over the whole surface at once.
The hot honey standard sounds like a column that doesn't break into drops.
Again, thanks, Wiley
Thanks Don. As to consistency, The advice I'm hearing in this thread points to a thicker consistency than I am used to on larger sawn-veneer glue-ups. I do like a heavy consistency on smaller surfaces, and especially where fast tack is. Important. I can recall making a complicated banding for a Federal type piece, and the fast tack combined with hemostats for dipping the parts made it go very quickly.
Your advice of 'get heat on it' jibes with Todd's.
THanks, Wiley
Thank you Dennis. Your consistency test is about what I do on sawn veneer over substrate. I am thinking from the three different replies here, that there is no single optimum consistency, but rather it depends on the application, for example whether you need fast grab or more placement time--but I may be reading the answers through my own lens rather than what the poster actually means.
As to the moisture balancing on sawn veneer, I hear you. When using hot glue, I am using glue brushed on both sides of the veneer, plus the substrate, and rebrush the outer surface with more glue if there's any hint of curl developing. On smallish things, like cockbead parts, I dip them wholesale into the glue, bring them out dripping, press into place, and hold.
Thank you much, and any critique of what I said is most welcome. I do try to use experience, but it would take a lifetime to rediscover the tested experience of those more knowledgable--hence I ask around and don't mind getting corrected.
Wiley
