Dovetailing drawer dividers...Ooops.
Once again I forgot that the back of the case will be rebated to receive the 1/2" thick back. The dovetail sockets needed to be extended 1/2" deeper than I had them. It was an annoying, but simple task, to chop out the extra with chisel, guide block and router plane.
....Gary, note the bottom of socket. To use the plane I make a forward cut and then many skewing cuts to smooth the bottom and get into the corners. It follows that the width of what is being planed needs to be wider than the blade to allow for rotation of the blade to make the skew cuts.
Re: Dovetailing drawer dividers...Ooops.
William Duffield
That's not how I would have made that mistake. :) Wouldn't it have been easier to rip a half inch off the width of the rear drawer blades?
This is the Hand Tool Forum. "Easy" not allowed! Excuse to chisel and plane more earns extra credit. :)
William Duffield
i can't argue with that line of thought, except maybe to suggest that exercise with a rip saw and jointer plane is good for you. :D
