Favorite part of case construction
I particularly like dovetailing the drawer blade dividers. In fact I dovetail all the dividers front and back because it is easy, enjoyable and leads to a fortress like case. Done right, the case self-squares upon assembly....happiness. 1 done and 19 to go. This chest of drawers is for one son-in-law.
Note that I use half tails. It makes adjusting the fit trivial. Too tight by a few thou? One swipe with the hand plane fixes it. Don't know why anyone would use full tails on dividers.
The other Son-in-law was visiting and we moved some cherry lumber sawed last fall. It is already as dry as it will get outside. Cherry dries quickly, even in the winter. A week in the 120 degree loft and it will be good to go. He requested a chest of drawers from it like the Chester Country piece I made some years ago with the 3 arched drawers on top. A lot of work in that piece. I will be busy until next winter finishing both these pieces.
Re: Favorite part of case construction
Hi Bill
I agree on the half dovetails. Much easier to adjust and get an accurate fit.
How did you make your sockets? It looks like you used a power router (dado a groove the same width as the base of the dovetail, and then add the half dovetail). If so, how did you do the half dovetail?
The curve at the front may not need to be squared up if the male section has a beauty rebate at the toe. Is that how you did yours?
How did you make your sockets? It depends on the case construction. For any case I place the sides together, ensure they are the same size and squarness, and mark together the drawer positions on the front edges. Then I butterfly these sides on the bench top and connect the scribe lines for drawer positions across the inside of the side panel. This scribe line across the panel side locates both the runner and the position of the drawer divider for the case back. This somewhat involved marking procedure ensures the front and back dividers and runners are all in the same plane.
For a flat panel case side I clamp a straightedge along the scribe lines and route a shallow groove with a pattern bit running on this straightedge. This groove accepts the runner, locates the drivider(blade) and starts the socket which I then continue to saw the vertical side to the scribe line and approximate saw the angled face of the socket, to be pared exact with a guide block later. If I had a dado plane of the right size I would prefer plowed the groove across the panel with a plane.
For a frame and panel side I usually saw the vertical side to the scribe line and approximate saw the angled face of the socket, to be pared exact with a guide block later. I establish depth with a router plane.
However.....this time I was teaching son in law case construction. For a number of reasons I tried for the first time to route a starting part of the socket using a straight edge and pattern bit, undersized for the tail. It worked ok but worrisome routing on an assembled side that took a lot of labor to make and precious wood.
If so, how did you do the half dovetail? ....A picture is worth a thousand words. This jig makes precise to the 0.001" drawer divider dovetails no matter the variance in stock thickness at a rate of 3 per minute. With all the dovetails exact it becomes easy to train the eye to get the socket perfect after 2-3 practice runs.
The curve at the front may not need to be squared up if the male section has a beauty rebate at the toe. Is that how you did yours? NO, I just partially squared it. Doesn't matter if it is oversized a bit.
