Re: Danish modern bed joinery
steve voigt
Brian and all,
Thanks for the replies--much appreciated. It seems the unanimous opinion is that the design needs some beefing up, and I agree. However, coming to agreement in my house on an aesthetically satisfactory design is comparable in difficulty to passing an international treaty, so the basic design will stay.
I agree with keeping the rails relatively low to the ground. And I was planning to add a center support for the slats, so adding one or two legs under that will be no problem--good idea.
I was also planning to use bed bolts at the back, so the headboard, rear legs, and rear rail will detach as a unit. There'll be an inner rear rail permanently attached to the side rails, to keep the rest of the frame together when the headboard is removed.
Below is the joinery for the rear legs to rails. One modification I'm considering is to use the same joinery for the front legs, but rotated 90°, so that the front rail would tenon into the side rails the way the side rails tenon into the rear rail. That might be stronger (and easier) than the miter-ish joint I showed above. I also think that the rail-to-rail joints should be closer--they look like they're at least an inch from the leg; maybe half that would be better. Thoughts, anyone?
