spear point router plane blades
Gary B.
I had some great UPS shipments from Lee valley lately which included their Small Plow plane, and router plane.
After some reading, it appears that the spear point router plane blade is meant for final smoothing of the recessed surface. The thing is, the blade itself is far from parallel to the recessed surface. It is angled down. When I try to use it, it hits a small area (say 1/4" instead of full width), and creates a furrowed surface instead of smooth. What am I missing?
Re: spear point router plane blades
Jim Matthews
You're not missing anything.
Mine aligns the same way.
Note that this blade should have the "tip of the spear" slightly rounded to avoid digging in. I bought the blade holder to get my blades so sharp as possible.
Light passes work best for me.
Hi Gary
I rarely use the V- (or spear pint) cutter. 99% of the time the straight cutters are used. I would disagree that the V cutter is for finishing as mine also would leave a furrow if used straight-on. The straight cutters get very sharp and create a better finish.
The V cutter seems best used, in my opinion, when clearing out corners or cutting against a wall. I use a slight slicing action together with a light cut, turning it into the section.
For all router plane blades, including the V cutter, I hollow grind. This makes them easy to hone and creates a razor sharp edge.
John Schtroumpf
"The thing is, the blade itself is far from parallel to the recessed surface. It is angled down."
That is normal, if the blade was parallel to the recessed surface, it would not cut.
Gary B.
Thanks for the replies everyone. I will stick to the straight blades for now.
I was kind of expecting a shallow flat on the spear point, so that it would register parallel to the recess, much like a paring chisel would lay on the surface.
"...if the blade was parallel to the recessed surface, it would not cut."
Not to get argumentative, but when using a chisel in paring mode, I often have the flat of the blade on the surface being pared - parallel, that is, to the surface. Why would it work there and not in a router plane?
Josko Catipovic
I take this as saying that each side of the (spear) blade is angled towards the wood so the cutting angle is not the issue, but the tip is set to cut deeper than the ends of the spear. It's a bit like having an uneven blade in a hand plane, with one end set to cut deeper than the other. The cutting angle is still correct, but the cut is not even.
John Schtroumpf
In real life, making something parallel never truly happens. If the blade of a router plane is off of parallel in the wrong direction, the heel of the blade will contact the wood first, and the blade won't cut well, if at all. So to make sure the blade cuts, the bottoms of router plane blades are angled a little, so that the cutting edge of the blade hits the wood first.
router plane post response
I have been using this plane and blade to establish the bottoms of dovetail sockets and my bottoms are level. As I recall they always have been when using it.
Re: router plane post response
Gary B
Interesting, do you have a "flat" on the bottom of the blade that is near parallel with your finished socket?
Blade tips a few degrees relative to surface being planed. See "Oops post".
