Frame and panel groove. tools and technique?
Joseph Piotrowski
greeting hand tool guru's,
my current project is filling some rolling carts(from rockler) with side and drawers. i am planning on sides to be peg board. i want to do a simple half lap frame of some pine laying around. i want to make a groove to insert the pegboard into.
so my questions is what and how to make a groove 1/4" wide.
who do you all make these frame and panel like grooves? plow planes? tongue and groove planes?
thanks,
Joe P
Re: Frame and panel groove. tools and technique?
Jack Guzman from Maine
There are quite a few options to make that groove with hand tools. Like Derek said a Plough plane or Plow as some call it. The stanley 44 ,my favorite,is a simple one of these. Lee Valley and Lie-Nielsen make their own versions. There are also wooden planes designed for this job. There are some quite fancy ones available. I believe that a particular plough plane made with ivory and ebony was sold on the antique tool market and got one of the highest prices ever paid for a used hand tool. A tongue and groove or match plane also does a fine job of doing this task. Whatever you use just make sure it is sharp or you will struggle.Enjoy the journey. Hand tools can be fun.---Jack
Tool Porn  *LINK*
Sandusky plough plane
William Duffield
You haven't mentioned how you are planning to join the stiles and rails. That makes a difference if you care whether the end of one of the grooves shows at the edge of the joint. Where it shows and how you cover it or fill it in depends on the type of joint. For example in mortise and tenon joinery you can fill it with a haunched tenon. With cope and stick, hiding it can be automatic. A stopped groove is also an option, but is much more difficult to execute with hand tools.
Since it is just a shop project, cutting the grooves with power tools might also be an option. For example, Lee Valley sells these router bits:
http://www.leevalley.com/us/wood/page.aspx?p=47818&cat=1,46168,69435,46176
that allow you to cut stopped grooves in one operation, after completing the rest of the joinery, using a forked-tailed routah. They work for frame and panel, and also for box bottoms and box lids. Another option is a dado stack in a table saw.
For simple grooves, I keep a 1/4" cutter installed in a dedicated Stanley #45, with the depth stop also preset to 1/4" and the fence preset to 1/4". For other depth, width of offset grooves, I like my Veritas small plow plane, because it's left handed.
Re: Half Laps
Wiley Horne--So. Calif.
It would help to see the rolling cart you wish to convert. It sounds like you're going to make a chest of drawers of sorts, and that's never very simple. To make the frame rigid enough to hold the drawer shapes, it becomes important how the top, bottom, and back are to be affixed, and whether you are thinking of a face frame. And how the drawer runners and kickers are to be managed.
I may be reading too much into the project, but it doesn't sound very simple to me.
Can you tell us a little more. I agree with the plough plane recommendation, but I suspect that may be the least of the issues.
Wiley
stands
Joseph Piotrowski
https://www.google.com/shopping/product/1603502046749227178?lsf=seller:1135568,store:10754508331030093336&prds=oid:15452844688884570954&q=rockler+tool+stands&hl=en&ei=nOhRWbiaO8bJjwScx5uQDg&lsft=gclid:Cj0KEQjw4cLKBRCZmNTvyovvj-4BEiQAl_sgQpqNKCgHmFNiW8MRiw_ULUXMJav0DalC0NyyJW2msS8aAv488P8HAQ
i picked up a few of these about 10 years ago or so. i just making it simple as can be. kind of like an erector set. no fancy case work. very utilitarian.
the left and right sides will be peg boards in a pine frame. screwed to the stand.
i'll screw some 2x2 to the corners and in the center. mount full full extension door slides. one side will be a bank of drawers. the other side will be a door with some pull out shelving to hold some items like my tormek .this will hold all my sharpening stuff.
i'll skin the back with whatever i have in the 1/4 inch size. pegboard, mdf whatever.
i wind up with very little joinery that matters. i'm just leaning some skills when i can by getting 1 or 2 hand tool operations in. my main objective with shop stuff is fast,cheap and utilitarian. i just need to get things in there place so i can have room to work.
Re: Half Laps
William Duffield
OK. If you are cutting, for example, 1/4" x 1/4" grooves with a plow plane (or a straight cut routah bit or a short dado stack), there will be a 1/4" x 1/8" hole showing in the end grain of the end of each stile and rail. They're easy enough to fill with a little plug, or to ignore.
Re: Half Laps
Joseph Piotrowski
it will never be visible so i'm ok with grooves showing.
at this point i may just rabbet them until i get a groove plane.
