using only a dovetail saw
david weaver
If one has a reasonably well filed dovetail saw with small teeth and some plate depth, it's not hard to use such a thing for small work both for rip and crosscut.
At one point, I filed fleam onto a rip saw on purpose to try to clean up the back side of a cut, and I asked Mike W. if he had ever done the same and he said 5 degrees. I've since figured that's kind of a waste of time unless you can't hide the waste side of your cut and you're getting unacceptable blowout. (In Mike's defense, if customers ask for a saw that doesn't blow out anyway, then it's not a waste of time for him).
At any rate, I've made 10 kitchen cabinets all M&T (except for coped doors) and have only used a dovetail saw to cut all of the tenons and shoulders. I have the hardware to use both types of saws, but it's easier and faster just to use the dovetail saw unless you're batching a bunch of crosscuts together.
That may not work quite as well if tenons were larger and a dovetail saw too slow.
I do think that the argument for a hybrid saw as a matter of cost doesn't hold much water, because the cost of materials for any substantial project will be more than the cost of a saw. In the end, the saw can be resold if it's unwanted - I'd bet the average woodworker using decent materials would have some difficulty recovering the cost of materials and supplies used.
