Live edge shelf and wall bracket.
Re: Live edge shelf and wall bracket.
david weaver
Lovely, Brian. The metalwork adds a dimension that most us aren't familiar with.
In terms of your work, I haven't seen custom work done with as much care anywhere around here.
Try plane is in that middle stage where it's not clean, and it's not dirty enough to look good dirty!! It strikes me that as much as you use the plane, I'll make you another one down the road a bit if you'd like (free, of course - no cost of materials or anything). I can make you a handle a bit more comfortable, etc. Just little differences.
At any rate, the work continues to be excellent, no matter the style being made at the time. The custom metalwork rather than using off the shelf parts just adds to it.
Kees
I really enjoyed the read and pictures. I can relate to heavilly warped slabs! Hopefully it survives the move to the other country...
Like David wrote, the metalwork adds something special to the project. I am not sure why the rods needed to be that precise in diameter. Wouldn't it work just as well with a mm of play in the holes in the wood?
That was nice work, Brian. Personally, I am not a fan of live edges, but I liked the way you selected the section, and the simple details you added.
Any idea what it will the used for, and if anything will be placed on it? It would be nice to see a photo of it in place.
Brian Holcombe
Thanks David! I appreciate the offer of your plane as well, very much so. I put a lot of mileage on this one and it works beautifully. You can probably tell a lot just from the dirt pattern left on the handle, WRT to where it is touching and where it isn't. That said I think it's pretty comfortable, it's definitely never fatigued my hand and my hands are relatively sensitive to that sort of thing. For instance I have a coping saw that I can't use for any real work or my hands will be screaming.
Hopefully it was a good surprise for most readers to see some metal work involved.
Brian Holcombe
Thanks Kees! They did not need to be so accurate but it is nice to work things in one's favor. I ended up using a 20mm bit and that allowed something like 30 thousands clearance. I was going to go for a real piston fit, but ultimately thought better of it. I may well be able to get the shelf on the wall, but then the customer would likely never be able to get it back off the wall if the fit were too tight.
Hopefully the move goes well, the weather is fairly similar, but I'm now nervous about the shellac. I was unconcerned when it was going down the street from my house, lol.
Brian Holcombe
Thanks Derek! I can certainly appreciate that, live edge is definitely not for everyone or every situation but in the right spot it's pretty cool. I like it used very sparingly.
Not sure what they will end up using it for now, they were sort of tossed into this move (work related) and so I'm not sure that they even have a home there yet. I'm sure they'll follow up with me once it is time to install it for some advice and guidance.
American homes, in some ways, are very easy to deal with since the great majority of them have stud walls. European homes are much better built, but I'm not exactly sure what they will be mounting to just yet.
North of the Border
Nicely done shelf and a very well thought-out wall-mounted system for such a heavy shelf.
There are some bloggers or online users who are well known for their blogging work rather than because of their actual project experience. I like to think of them as socialite woodworkers who chase for coverage, exposure and online recognition to satisfy their egos (these include both men and women). They may have some skills (e.g. in Japanese woodworking), but lacking in actual and diversified building experience (you can easily tell from what they share online; they may have completed just one or two builds and pretend to be experts, offering advice and sharing glorious tool shots in their "columns" in all kinds of social media).
You are clearly not one of them.
"You are clearly not one of them." Amen
Thank you both!
