planing long thin strips-how to hold?
How would one hold a strip 42 x 1/4 x 1/2" to plane the 1/2" (wider)face?
Re: planing long thin strips-how to hold?
Warren in Lancaster, PA
Usually we plane against a single stop. However, thin stuff will buckle if it is long enough. For 1/4 stuff the threshold is about 24 inches or so. For your strip we clamp the back end and plane away from the clamp. Then we reverse the stick and plane away again. If the strip must be planed in one direction, we sometimes plane toward the clamp.
Hank Knight
Bill,
I made a jig for planing thin pieces. It is simply a long, narrow piece of 1/2" BB Plywood with two carpet tacks driven side-by-side into the surface at one end. I clamp it to my bench top with dogs. Use more than two tacks if the width of the work piece calls for more. The heads of the racks are just proud of the surface and catch the edge of the work piece at the far end. I sharpened the edges of the tacks with a fine file so they actually grab the work piece a little. The tacks seem to work better than just a thin board for a stop. If the tack heads are low enough you can plane right over them without damaging your plane iron if you're careful. As Warren said, clamping the tail end of a long, thin work piece will prevent it from buckling.
Hank
GolfSteve in Calgary
Agree...clamp the tail end and plane the strip in tension.
The other thing I've done is use two-sided tape to hold the piece to the workbench. Very handy, quick, and useful for one-off jobs.
The attached picture is a planing stop I used when building a guitar. It was useful for holding thin long pieces; in some cases you could plane diagonally against the long stop and avoid buckling. However for very long or very thin strips I would mostly clamp the tail end and plane the board in tension. The maple guides were glued to the MDF substrate then run through a planer until they were slightly thinner than the boards I was planing (around 1 mm thick).
Another tip is that when planing long thin strips, it can be useful to use a massive plane, such as a #8. The length of the plane holds the strip down and can help to limit buckling. But...watch what you're doing as it is easy to buckle and break the piece.
William Duffield
Instead of tacks in the end of my sticking board, I use steel flat head wood screws. They are easily adjustable for the height of the stock being planed, using a screw driver.
Dyslectic interpretation leads to success
"It is simply a long, narrow piece of 1/2" BB Plywood with two carpet tacks driven side-by-side into the surface at one end."
Oh, you mean the other end?
I misinterpreted where the tacks went until I saw Williams post. In any case the misinterpretation works dandy. The long plane probably helps but this is the only plane I like to use so through dumb luck and awkwardness the strips got smoothed. I'll have to remember this one.
Todd Stock
All good approaches...a wood handscrew clamp can be used as below in a tail vise (first link) or clamped to the apron of a bench (second link):
https://tinyurl.com/k8b24tl
https://tinyurl.com/kwe3q9n
AlanWS
Siemsen demonstrates several simple work holding procedures here: https://www.youtube.com/watch?v=yvhn-PAfEW4
He planes a thin strip as Warren describes starting at about 23:30.
William Duffield
Thanks for the pictures, Todd. That's a very useful hand screw technique, and one I hadn't seen. Hand screws are about the most versatile appliance in the wood shop. I have filed your photos away, where hopefully I will find them when I need to use that trick.
Wow! You're right, that really is
Wiley Horne--So. Calif.
something new. Where's the best place to find wooden clamps?
Wiley
Re: Wow! You're right, that really is
Todd Stock
Adjustable Clamp of Chicago, IL used to manufacture a half dozen sizes of handscrew clamps, with all of them useful for clamping or as a temporary vise (clamp or screw one vise in place, etc.). With their demise, the inexpensive overseas-sourced tools work, but I've found that Dubuque Clamp Works of Dubuque, IA makes a tool that is at least as good as the Pony/Adjustable/Jorgensen-branded ones, with decent plating on the steel bits and nicely finished edges on the woodwork.
Dubuque also makes the second best cam clamps I've found (after Klemmsia) and in the very useful 6" depth size that I cannot seem to find short of ordering from an EU vendor. Available on Amazon, but a bit less expensive and quicker delivery from TFWW and Highland.
Bessey makes a handscrew clamp line, but like most of their stuff made outside Germany, is a cut below their old stuff.
Another source is to buy used and refurbish...a bit of time with a plane or fine-set jointer can provide nice, clean jaw tips.
Good to see you are still here, William - did a quick pass through PATINA this year and somehow missed you.
William Duffield
Hi, Todd. Good to see you here on WoodCentral. I didn't make it to PATINA this year due to a schedule conflict, specifically a SAPFM meeting at Gunston Hall in Lorton, VA.
Lee Valley carries Dubuque clamps and clamp kits.
http://www.leevalley.com/us/wood/page.aspx?p=69825&cat=1,43838,47843
http://www.leevalley.com/us/wood/page.aspx?p=69826&cat=1,43838,47843
However, L-V doesn't state the sizes of the holes you need to drill for the barrel nuts, and that can be a problem if you want to build the kits. The barrel nuts for the four largest sizes are 5/8" in diameter, and they need to be a loose fit in the holes you drill in the jaws. I recently posted an explanation on how I solved the problem of drilling 25/32" holes in hard maple on the turning forum.
Re: Dyslectic interpretation leads to success
Hank Knight
Bill, dyslexia may be a good thing! Sounds like you have accomplished your purpose; but for future reference, Google "sticking board images." You'll find hundreds of photographs of sticking board designs. My two-tack idea is a crude interpretation, but it gets the job done.
Re: Oops *LINKS*
William Duffield
The holes were 21/32" (a smidgen over 5/8) not 24/32" (a smidgen over 3/4"). I made the same mistake in my original post on the Turning forum.
And, the interesting links were in my previous message, not this one. I was expecting WC to figure out they were there, but it didn't.
TomD
I have done hundreds of strips for this, I even made a special bench, though that was completely unnecessary. I hand plane strips for canoes, bow limbs (tapered), battens for sails, parts for guitars.
I just hammer in a nail with a slight angle away from the pull, clip the head off, and then I press the strip onto the nail head.
With some projects like bamboo rod strips, I just hold the strip with my off hand, and sorta scuttle hand over hand, at least to get it started. Some guys use a toggle clamp once the end has been worked.
If for some reason a huge amount of force is require, I use a plug cutter to cut a hole through the strip, this leaves bevelled edges. I use a screw, adjusted so it will not strike the blade, I use bronze. Because the screw head an hole interlock, it is very solid.
On some projects like tapered battens a certain part will not be planed. In that case I use a rope and wedge, such that the planing force pulls the rope tight and the wedge jams the strip.
For certain products that buckle, but so far not strips, I use a vacuum jig.
In many of these projects I use runners on the plane so I get a perfectly dimensioned strip to the thou, with zero effort.
