Employment for the shooting board
It is time to install the glass in the display cabinet. Will this project never end?
Step 1 is to make a mile of the filler strip that will be bradded in with brass escutcheon pins to secure the glass. I’ll ask about planing it in another post. After mass producing these strips I trimmed a finish cut on one end with the table saw with a 40T 7 ½ blade.
Step 2 Each strip must be fit to its space. A shim is added under this strip to simulate the glass that will be added later. The strip is held in place and the finished length marked. From here there are lots of options. Running back and forth to the table saw to complete the fitting is not a convenient one. The strip is cut a bit long with this worn out miter box clamped in the vice. The miter box just provides a handy way to hold the strip for sawing. The spring clamp on the end of the saw is essential. Otherwise the saw would fall on the floor as the picture was taken.
Step 3 I like a bit of spring on parts like this one which forces the ends into where they butt. One could just saw the strip to finish length and hope for a perfect spring. I like to sneak up on the fit-to-length while feeling for a desirable spring- adjusting the length on the shooting board until it feels right. With everything at hand on the bench this process takes a minute or less.
Ideally it all ends well.
Step 4 With the strip in place the pilot holes for the pins are drilled with the optimum sized number drill. It must be easy to install the pins with the glass in place. I usually force them in with a C clamp rather than pounding with a hammer. Later the holes in the strip will be enlarged to achieve a snug friction fit of the pins. Now it is off to get a home improvement loan to pay for the glass. >(
Re: Employment for the shooting board
Brian Holcombe
Why do you use a rip saw for cross cutting?
Multitasking
I presume you are referring to the Japanese saw?. Hadn't a clue. But it fits the miter box slot and cuts quickly, way more quickly than the saw the box was made for, which I now never use. "Gent saws" have all the disadvantages of Japanese saws and cut slow to boot. I might "better" be using a bench hook and LV cross cut, but the shooting board is occupying the bench hook position and the vice was clear to hold the miter box, AKA miniature double sided bench hook.
I bought it inexpensively from Japan Woodworker back when we had a wholesale dealer account there. Woodcraft acquisition killed that arrangement. I tried it for dovetails and didn't like it. Son-in-law, on the other hand, prefers it. I suggested he buy his own. Occasionally it fits a task so I keep it around. So long as it cuts fast I'm happy.
Thanks for the C-clamp trick.
Chuck Nickerson
I'm currently building a frame for a circular stained glass piece. Given that the back of the stained glass is not flat, the C-clamp is a much safer approach for driving the brads.
Re: Multitasking
Brian Holcombe
Many excuses :D
A proper crosscut dozuki would amaze you if your current experience is using a rip cut saw. They can be had quite cheaply.
Thanks for the show and tell
I've used a similar process for installing glass retaining molding - although, pessimist that I am, I use small brass wood screws, so I can remove the molding more easily when the glass gets broken.
When I've pushed brads into molding like that, or into picture frames, I've used Channellock type pliers with masking tape to protect the finished surface. I can see what I'm doing with the pliers. Your clamp is a nice alternative.
clarification.
Bill Tindall
I am forcing the pin into a predrilled hole. A snug fit will keep the pin in place, the glass in place and the strip can be removed safely if the need ever arises. I drill practice holes of different diameter to get the fit right for the wood density involved.
Do you use your number drills,
Wiley Horne--So. Calif.
or does 1/16" usually work out?
Wiley
Number drills
I could not get on without number and letter drills. I use them all the time to drill perfectly sized holes for brads, screws , etc.
For the pin I want a hole that provides just sufficient friction to hold the piece in place.
question
How do you get a screw driver engaged? Seems like the glass would impede the handle from being in optimum position, and then how to rotate the handle with glass in place.
Re: question
Very small screws lead to very small screwdrivers, with correspondingly small handles; that helps.
The small brass screws I can get locally have Phillips heads, which allow a bit more "lean" to the driver as long as you're not applying much torque. Not my preference aesthetically, but the Phillips configuration also helps in driving already-driven-before screws.
Between the two, it works.
Re: Maybe a Krazy Idea? *LINK*
William Duffield
Might something like this work for installing the brads?
https://www.kregtool.com/store/c46/corner-clamps/p389/right-angle-clamp/
