General File question
Of the teeth patterns for "ordinary" files, for example first cut, second cut, etc. what pattern is most aggressive? In researching files I keep encountering terms for teeth I don't understand, "American Pattern" for example. Is there a source to be found that explains these terms, particularly in terms of their cutting performance and result?
Re: General File question
david weaver
American patterns by coarseness.
Coarse cut, bastard, second, smooth
Single or double cut.
The only other pattern I've used is swiss, and they are graded by number and double cut (I've never used a file that was coasre in swiss pattern, so I can't comment on usefulness for wood).
Old simonds guides recommend a type of file called a "cabinet file" for wood, or a rasp, of course.
I've never seen one.
For reasonable wood removal rate, you want something coarse and double cut, and to refine it, bastard single cut - you can go to sandpaper after that.
Rick W
A cabinet file is just a half-round file with a flatter cross- section than a regular half-round file. They have coarse, double-cut teeth.I think they are still made by Nicholson.
Rick W
Re: This might help *LINK*
Hank Knight
MSC Industral Supply - FILES
david weaver
Thanks, Rick. Something worth tracking down given the price of rasps.
Ah, that's the decoder ring I was looking for
My previous "knowledge" was all wrong.
Re: Ah, that's the decoder ring I was looking for
I have since discovered that most of my files have their tooth style stamped on the file, though in dim font that I never had looked at.
you should also consider milled tooth files
ian neuhaus
Hi Bill
I've found the milled tooth files which Lee Valley carry very effective at cutting wood, plywood and epoxy adhesive
Japanese version http://www.leevalley.com/us/Wood/page.aspx?p=63451&cat=1,42524
Nicholson version http://www.leevalley.com/us/Wood/page.aspx?p=56529&cat=1,42524
BrianMonumentCO
Nicholson-guide-to-filling
http://www.nicholsontool.com/MagentoShare/media/documents/nicholson-guide-to-filing-2014.pdf
William Duffield
That is a very useful document. Thanks for finding it and sharing it with us.
BrianMonumentCO
I wish I could find an online copy of the nicholson file writeup I was given while at gunsmith school. IIRC it had a somewhat different set of info.
It's got 'Fileosophy' in the name,
Chuck Nickerson
or something very similar ('Filosophy'?). I have it in hard copy but not digital.
Re: "File Filosophy" *Link*
William Duffield
http://www.wewilliams.net/docs/1920%20-%20File%20Filosophy%20by%20Nicholson%20File%20Co.-%2011th%20Ed.pdf
