Mortising video *LINK*
Kees
Here is a video of my mortising technique, using a typical Dutch mortising chisel. I allready posted this on sawmillcreek and got Warren's kudo's :D ;)
Comments are welcome, or share your own technique, maybe even with a video?
https://www.youtube.com/watch?v=msLW0yrW3KA
Re: Mortising video *LINK*
Kees
And sawing the tenon cheek. Not quite as fluently I am afraid. need to work on my sawing technique.
I first define the sawcut on top of the tenon and then on the side facing me. Somehow I can't get them both at the same time, always wander in one or the other.
Please share your own technique too.
https://www.youtube.com/watch?v=bA2Acam4uRs
Re: Mortising video
I am not as patient and I usually make a deeper mortise. To speed things along I drill an undersized hole at each end of the mortise. The hole is a bit smaller than the mortise and it is close to the end....hence it can be drilled free hand and quick. The hole provides clearance so that the initial penetration can be nearly as deep a the target mortise depth, and it provides a target depth. If I drill on the drill press the whole is also guaranteed to be perpendicular to the face of the mortise, which provides a reference for the chiseling.
I typically mark the target depth on the chisel with a magic marker.
What wood are you mortising?
Re: Mortising video
David Weaver
Looks good, kees. No fiddling, no strange jigs.
Re: Mortising video
Brian Holcombe
Nicely done Kees, that mortise chopping is excellent.
Re: Mortising video
Kees
Actually i like the mortising bit of M&T joinery. More so then the tenoning. Going deeper is not much more work when the initial hole is established.
The wood is cherry.
Re: Mortising video
Larry Barrett
Kees, on the return trip (around the 4:00 min mark) had you thought of turning the chisel around so that you get a little more prying action as you near the start?
Have you tried this in green wood, where the chisel doesn't easily sever the wood fibers in the side walls as you push it fore and aft? In my experience the fibers tend to cling together so you don't get the nice pop out action as readily.
Re: Mortising video
Kees
I don't think it really matters so much which way the bevel goes after the initial sinking of the hole. Both sides work but for me it seems a little easier to do those last parts with the chisel straight up.
And no, I have no experience with green wood.
Chris Scholz
Re: Mortising video
Chris scholz
Every time I need inspiration on mortise and tenon techniques I mosey over to Master Xin's 辛师傅 channel over at Youku. The precision, efficiency and speed he works with never fails to amaze me. I guess there is a big difference if you do it as a hobby or to make a living.
Here are two videos of what appears to be one of his senior students chopping a double mortise.
Part I:
http://v.youku.com/v_show/id_XMTUxMzg2NzgxNg==.html?from=y1.7-2
(chopping mortises 13:00 min to 27:00 min, cutting tenons 30:00 min to 45:00min)
Part II:
http://v.youku.com/v_show/id_XMTUxMzg2ODAwNA==.html?from=y1.2-1-103.4.1-1.1-1-2-0-0
Here's the master himself:
http://v.youku.com/v_show/id_XMTUwMTE2NDY1Mg==.html?from=y1.7-2
