Cleaning a burnisher
At a yard sale Saturday ($1 per tool - I spent $15), I picked up a nice little oval burnisher, which had, alas, spent too much time with water, and got rusty.
I've got some crocus cloth. Is that the best way to polish it up?
Re: Cleaning a burnisher
david weaver
Do you have a belt sander that has a platen area and a slack area? If you do, I would use the belt sander slack area to do the heavy work.
I haven't restored a burnisher, but I have had small patches of rust to remove with progressive paper (like a burnisher, the straight razor has to be uniformly fixed or it will look funny - although the burnisher function is affected negatively, too) and it has always taken me much longer to get to the depth of the pitting than I expected, and then a subsequent long time to work back to a uniform polish.
The bonus with a razor is that you get to do it both trying to avoid damaging the bevel as well as trying to avoid letting your fingers get cut by the edge.
Belt sander would be the way I'd go for the coarse work through the finest belt you have, even if you only have a hard platen type (woodworking) belt sander.
Why bother?
The ultimate burnisher is a piece of carbide rod, and it's cheap. I would not find the cost of sandpaper to smooth out the pits (It is the same process as flattening the back of a rusted chisel) to be cost effective.
But if you must.....it is just like grinding out the pits in a chisel back. Coarse grit, be it a stone or paper, and work finer until you get the finish you want.
a word of warning
Bruce, a MN Galoot
Wear a dust mask if you polish that rod on your sander. Carbide dust is really nasty stuff to get in your lungs.
carbide?
He said oval, so it is likely one of the obsolete oval hardened steel burnishers. Anything that is used to sharpen tool steel will abrade it and hence remove rust and pits from this burnisher. A tough abrasive like aluminum oxide or zirconia would be best. Silicon carbide will crush prematurely on hardened steel.
BTW, when did sand paper go through the roof? I went to order some finish sanding paper and the last I bought was about 30 cents a sheet. It was nearly 70 cents at Klingspor and a dollar at LV. At these prices hand planing acquires an economic incentive.
Re: carbide?
Bruce, a MN Galoot
I once was a guest in a 3M employee store and walked out with 100 sheets of 400W/D sandpaper for the princely sum of $1.00. I'm down to about 20 sheets and will really hate to start paying retail.
Re: carbide?
TomD
There is nothing obsolete about the hardened LV oval burnisher, or essential for that mater. But it works great.
Hardness in the burnisher is in any case no biggie, you are pressing on the side of the edge and deflecting it. The ABS edge chip test uses a piece of brass for that. Another material that will easily get the job done for a buck or two is a HSS tool bit, by which I mean a bit for a lathe or milling machine. Drill bits, screw driver shafts. It's not like selecting rods for the nuke plant.
If you want to get the pits out of metal you will end up spending more on sandpaper than a new bit. And I would guess one does not own the appropriate machinery for the task (grinders buffers, etc...). Seems as though a new part would be cheaper.
Probably half this price in the US:
https://www.amazon.ca/CNBTR-Silver-Speed-Steel-Length/dp/B01D4LVA78/ref=sr_1_5?ie=UTF8&qid=1493197626&sr=8-5&keywords=hss+lathe+tool+bit+round
William Duffield
Repurpose it, for example as a draw bore pin, and as the others have suggested, use a highly polished M2 HSS drill blank or the shank of a carbide mill or water jet and make yourself a new burnisher. More appropriate materials will also end your future corrosion problems. The one you have worked fine for English card scraper steel, but it will gall if used on harder Sandvik or Bahco Swedish steel scrapers or a L-N #112 blade, and then the scraper hook will fail prematurely. As a draw bore pin, any pitting not easily removed will not adversely affect its functionality.
I never understood the usefulness of the ovoid cross section of these. It's superfluous "bells and whistles".
