mahogany
mahogany
mahogany
Bruce Mack
I received a 2 inch thick piece in 1990. It is not old growth. I'm using some (resawed) to make a small reliquary box for ashes. I plan to use filler on the pores, being sure the filler is darker than the wood. I've had success with tinted shellac as finish for other dark woods but want to avoid the fuss and the rubbing out. Perhaps a reddish stain followed with Tru-Oil. I have the powders for the stain, but again want to skip the alchemy. Any out-of-the can suggestions? Thank you.
Re: mahogany
don't like the oil idea
It makes no sense to me to fill mahogany and then put a "cheap" finish on it. The whole reason for filling is to enable a high build top coat to be rubbed out glass smooth. How hard can it be on a small box compared to building the box and filling?
Re: mahogany
Re: don't like the oil idea
Bruce Mack
Tru-Oil rubs out well with steel wool and rottenstone to a uniform sheen, and is a quality finish in my opinion. I'll experiment and report back if I am able to post a picture.
Re: mahogany
Unfamiliar with Tru-Oil
Some of the things that are called "oil" are in fact wiping varnish, which will build to a suitably thick coating to look elegant on a filled mahogany. A true oil (linseed , etc.), on the other hand, does not easily build to a film that approaches varnish or shellac in appearance on a filled wood. Such an oil yields too informal an appearance to be appropriate for filled mahogany. Even the "oiled" finishes popular in the 50's-60's were in fact not oil finishes. They were low build varnishes of one kind or another.
I have a friend that builds jewelry boxes for sale at craft stores. He uses a wiping varnish for them and they look as good as a conventional varnish. It does take 3-4 coats to get this elegant finish.
Re: mahogany
Its basically a wiping varnish...
John in NM
Just takes lots of coats. I tried it once, works fine but I prefer Waterlox - but in all honesty, I suspect I wouldn't be able to tell the difference between pieces finished with either one.
I too would probably use one of these instead of shellac. They seem less fussy to me, and you don't run the risk of that crackly finish in 50 years (assuming one thinks this way).
Re: mahogany
Re: Unfamiliar with Tru-Oil
Ron in Sterling, CT
As John said, it is a wiping varnish, and is used primarily for gunstocks. I use it on plane knobs and totes, and after 3 coats and rub out with 4/0 steel wool they shine and look like new.
