THE WOODRAT IS BACK!
Acquired job lot of joiners tools.....
Jeff200sx
Hello all, I recently acquired 7 joiners tool boxes and contained within were some amazing items. All in fantastic condition, I am having a hard time identifying a few items and I would appreciate any help you guys can give.
Infill plane, 17 3/4 inches long, no maker stamping that i can find aside from Hearnshaw bros John Bull Sheffield. Took it to a friend who suspects it may be early Norris before full branding was used? Although I was leaning more towards Spiers of Ayr or a homebuilt kit.
I have been unable to get much of any information online on this model or even size, the sole measures 17 3/4 inches and most I have found info on are 17 1/2.....
I'll add a link to photo bucket for pics of this plane but i will also try to add pics directly to this post.
http://i155.photobucket.com/albums/s285/jeff_gormley/IMG_2309.jpg
http://i155.photobucket.com/albums/s285/jeff_gormley/IMG_2310.jpg
http://i155.photobucket.com/albums/s285/jeff_gormley/IMG_2311.jpg
http://i155.photobucket.com/albums/s285/jeff_gormley/IMG_2312.jpg
next up is a preston no 1364 1/2 Irish pattern chariot plane
http://i155.photobucket.com/albums/s285/jeff_gormley/IMG_2323.jpg
http://i155.photobucket.com/albums/s285/jeff_gormley/IMG_2324.jpg
Stanley 3" router plane in mint boxed condition
http://i155.photobucket.com/albums/s285/jeff_gormley/IMG_2313.jpg
http://i155.photobucket.com/albums/s285/jeff_gormley/IMG_2314.jpg
http://i155.photobucket.com/albums/s285/jeff_gormley/IMG_2316.jpg
Stanley Compass plane type 4a
http://i155.photobucket.com/albums/s285/jeff_gormley/IMG_2319.jpg
Norris No 10 infill rebate plane
http://i155.photobucket.com/albums/s285/jeff_gormley/IMG_2321.jpg
Stanley No 98 & 99 side rabbet planes
http://i155.photobucket.com/albums/s285/jeff_gormley/IMG_2318.jpg
Re: Acquired job lot of joiners tools.....
Congrats on your acquisition
Gary Smyth
But what is it you want to know? If you can identify the plane what is it you're after? Confirmation? Photobucket takes a long time to come up and worse there are ads that have to assemble before getting to the pics. Photobucket is a loss for me. About all I can tell you now is that the Stanley box condition is good (not fine or mint).
Re: Congrats on your acquisition
Jeff200sx
Sorry about the photbucket links then i was unsure if it would let me even add the pics as the limit I noticed was 100kb so as a backup i added direct photobucket links.
What I am looking info on is primarily the Infill plane as I'm drawing a complete blank, the size of it is unusual as most similar designs are 17 1/2 inches long, that one is 17 3/4, there are no makers stamps on the plane at all, so aside from google image results which show plenty similar designs i cannot find an exact match to be able to search out further details.
The Norris 'No 10' is also an enigma as the plane carries 'Norris London' makers stamp on the front and 10. stamped below the iron and wedge yet a norris number 10 is a different animal all together from what I can see online. Closest I can find is a number 8 shoulder plane which 'seemed' to be all dovetailed and this is not.
So those are the two I'm hoping some kind soul can share a little light on for me or point me in the right direction.
As for the router plane.. I dont mean the box is mint, I was referring to the plane itself! the nickle plating is unblemished from new yet it has indeed been used as the cutter shows signs of use and honing. interestingly the box does have its original price written on the bottom 11/6.
david weaver
The infill plane doesn't look like Mathieson, Norris or Spiers.
Those planes had marked lever caps with more refinement on the cap and screw. I would suspect that plane was made from a mail order lever cap (you could buy that stuff in hardware store catalogs in the UK).
Mathieson, Norris and Spiers planes of Rosewood age generally had nice filed chamfers on the steel parts of the planes, and the cap iron and screws were very refined looking (and perhaps all or nearly all were stamped with a name).
david weaver
As a follow up, the infill is interesting, because it is nicely made.
I have an 18 inch buck infill plane (it's an older norris with a ward iron, but the buck mark is very proudly displayed on it despite it being clearly a norris plane), i'll measure it. I don't know that there was that much uniformity in the length of long panel planes.
As far as user made planes go, I have one of those, too (by that, I mean one I didn't make - I've made a few) - it is here:
http://www.tooltique.co.uk/product/antique-14-%C2%BD-long-scottish-infill-panel-plane-in-style-of-mathieson-or-spiers/
(it's out of stock because it's in my shop). It is a very well made plane, also speculated on the UK forum that it is a hardware store lever cap and either locally made or mail ordered casting. I got it not because I need it, but because it didn't cost that much and I could tell that the casting was in good shape (and the mouth) and that the handle was made at an angle that I really like.
As long as your plane's handle isn't too upright, it should make a nice user.
Jeff200sx
ahhh brilliant info.. I tend to agree on the kit made idea, I found it unusual that no makers stamps were on it.
As for its ability...yep it works lol. I just went out and stroped the iron a bit and had a play, transparent shavings as it sits and its probably the first time its seen wood since the owner passed away. Not quite full width as the iron could do with a good homing and I'll admit totally that setting the blade depth is new to me so getting it backed off sufficiently to allow the tool to do its job was difficult I also found really hard to set the blade square, it's a bit of an art I guess.
Wiley Horne--So. Calif.
Hi Jeff,
Welcome! On the rebate plane, I suspect the '10' stamped into the bedding was used during manufacture to match the bed to the original wedge. Likely the original wedge also had a '10' on it. A way to keep the parts matched during the making. A Norris expert could confirm this or rule it out.
You likely already have this Norris catalog link, but I have found it useful over the years:
http://www.20thcenturyfashion.co.uk/tft/nguide.htm
I'll check tonight whether that panel plane shoe looks like any in the E. P. Preston 1909 catalog. Preston sold shoes as well as whole planes. Just on the off chance.....
Wiley
setting the iron..
david weaver
On an infill plane with no adjuster, the easiest way to set the iron is to put the plane on what you want to plane (presuming you've set the cut too deep), and loosen the lever cap and then tighten it again. The iron should reset itself to zero or close to zero. You'll develop a rapport with a plane. The one I showed, I can do that, and then give it a light tap with a small steel hammer and it's just ideal for finishing a panel.
Once you have the depth set, you can adjust it laterally by tapping the side of the iron with a small hammer.
If one side of the lever cap has more grip than the other (not uncommon in old planes), put a piece of tape on the side of the bed that's loose.
Re: setting the iron..
Jeff200sx
I had never thought of doing it that way, I was always starting off sighting down the sole as I would with my normal planes and a few tries maybe with scrap to ensure levelness. Thanks ! I do like how it feels to use it's like a more sure of itself version for my 41/2 Stanley although the stanly can take as fine shavings and is easier to tune. I might mess about with the iron a bit and hone it properly just to see what it's like although to be fair to the owner aside from the bevel being a tad used looking there is nothing at all wrong with the edge he put on.
Out of curiosity what angle is your one beveled to?
John Aniano in Central NJ
Jeff,
Nice Haul! Perhaps the "10" under the iron/wedge is the number used to match up the plane body to the iron and wedge. They may have made a lot of planes at one time and there was a need to keep the various parts with each assembly. I've seen this before on infill planes. Just a thought...
John
david weaver
Should hold up fine at the same bevel angle as any other plane. I sharpen mine with a final bevel angle of 32 or 33 - I sharpen freehand so every plane iron is pretty much the same.
I've noticed that the parallel irons that have come in my infill, and that I have bought separately, are a click or two harder than the irons that I've gotten in wooden planes.
Hi Jeff
The infill plane - the length of a trying plane - appears to me to be a copy of a Spier.
Here is yours ...
Here is a Norris ...
In the body shell side curves, the Norris is more defined, while yours are rounded.
The infills are similar but not the same as a Spier, and the body also differs ..
The handle is closest to a Spier (more vertical).
The lever cap is quite different from either a Norris (above) or a Spier (below) ..
The lever cap screw is similar to the later Spier and a Norris, but this is a common shape of that period.
So I'd conclude that it is a good copy - it looks very well made - and I would sharpen the blade and use it.
