OT: light bulb heat
OT: light bulb heat
Jack Guzman from Maine
OT: light bulb heat
I use incandescent 150w or 200w bulbs to heat my chair parts kiln. When buying the bulbs I have a choice between soft-white or clear. Not knowing the difference I grab whichever is closest.Is there any difference in heat output between the two options?---Jack
Re: OT: light bulb heat
Joseph Piotrowski
i can't believe that there is a thermal insulation properties in a bulb coating. they both burn my hands equally!
Watts is watts. It will all become heat in a closed container. matters not the coating, just the current and voltage in expressed as watts rating.
If you get short lamp life there are other ways of heating, heat tape for example.
david weaver
More radiant heat from the clear bulb. The soft white bulb would absorb some of the radiant heat and release that at the surface (convective heat?).
Practical difference likely zero inside a box.
My mother puts a soft white bulb in a box when she gets a stray cat (lives along a main road rural, which means people dump off unwanted pets so they can be someone else's unwanted pet), but I think she has the idea that she's somehow providing more comfort because it's "soft"!
I have three ceramic fixtures in a row that I use with a thermostat that kicks off the power when it reaches 125 deg. How could I set it up with heat tape? My only experience with heat tape is the stuff you wrap around plumbing pipes to keep them from freezing. If I got ,lets say, a 25 foot length of pipe heating tape and coiled it around the inside of my kiln against the insulation lining the walls. Would that cause the air inside the kiln to reach 125 deg.? I know that heat tape of this kind becomes warm and as a result the warmth is transferred to the pipe it is attached to. However I have never felt any radiant heat coming off of this tape when in use. Is there some other kind of tape? If so where can I find it?
John Veerkamp
Instructions with the heat tapes call for wrapping in insulation wrap(specifically their brand) for better results. I've used it in the bottom of seed starting trays to keep the soil warm. Some heat tapes don't have a built in thermostat, but can be plugged into a thermo that goes on a regular outlet. Some of these have temp adjustment. Check your local farm and home store in the poultry section.
It is all about watts. Doesn't matter the source of the watts. Anything that heats while delivering the watts your lights deliver will heat exactly the same. Three 150 watt lamps is 450 total and that might be more frisky heat tape than you will find at the local farm store. There are other kinds of heaters that could work too. Forget what they are called but there is a kind that gets stuck in a hole in a piece of metal, for example, and they can be found at any wattage.
I'll stick with what works
Like I figured,it's going to take more effort that it's worth to me to find an alternative. My system works perfectly for my uses. I don't mind changing bulbs. It's not that big an expense considering the work I get out of it.
Now if they completely eliminate incandescent bulbs I will have no choice,but that hasn't happened yet.---Jack
Re: I'll stick with what works
TomD
It's happening up here. My bow oven, and guitar side bender work on light bulbs, and there are superior alternatives for either, but they are spendy (silicon heaters, cheap versions on ebay from chinesium). Some guys are using the heat guns for bamboo rod ovens, since the temp switch in my bow oven is out of a water heater, it would work just as well with that, though I don't know how it would cycle
I'd like to know more about the kiln
Keith Newton
How many parts do you put in there at a time,?
How large is it, and is it enclosed, keeping the same air trapped in there, or is there some turnover?
How long do your parts take?
My kiln
The kiln is roughly 2'x2'x3' lined with solid foam foil backed insulation.it has an opening low on one side and on the opposite side is a similar opening in which I inserted a small computer fan to move the air through the kiln. There is only one shelf so I am limited to what fits but I can get all 22 spindles for a settee in there at once. Typically it takes 3 days to go from freshly felled tree wet to totally dry.---Jack
Long life bulbs
david weaver
You've probably seen them already - there are various places online selling 20,000 hour incandescent bulbs that are more similar to the bulbs that existed before the bulb consortium settled on a 1000 hour bulb lifetime to create turnover or purchasing churn. Just in a brief look, they're about $1 to $2 per bulb.
They are lower in lumens, but I doubt you'd care about that. I can't imagine that their heat output would be much different than a bulb with a more flimsy filament and higher lumen output.
sounds good
No,I haven't heard of those. I will definitely check that out though.thanks---Jack
Re: Long life bulbs
TomD
Cool David!
