Display cabient-time to install hinges
There has been a shortage of furniture building expressed here. Filling the gap.....
I install the hinges on the door, burying the barrel almost half its width. Then I mark the hinge position on the cabinet off the door. I am paranoid about marking and having something slip so I usually fix the position, in this case with clamps, before marking. After marking the position I take the hinge off the door, position it on the cabinet and mark the length of its outline. The depth is done with a marking gauge set to not quite half the width of the hinge, including barrel.
I have had cases where all hinges are not created equal, so I always mark the actual hinge that goes in each position. In this case the leaf sizes were exact, but the hole positions were not exact.
While I am fitting it is with only one short screw in the middle hinge position. I will permanently install the hinge with 3 longer screws when the door goes on permanently.
Note the cabinet back is walnut, not ash. We tested backs and the cut glass looked better against walnut.
There was worry expressed that this design would be flimsy. As expected, once the back was tightly fitted it is not. The back is not even glued in yet and the case has become stiff. Not my invention. I learned it from the Krenov school of display cabinetry.
Re: Display cabient-time to install hinges
Very nice design.
Bill, I do the same as you with the hinges. You are not alone in being paranoid about movement! :)
Here is a link you installing Brusso square-ended hinges in the Lingerie Chest:
http://www.inthewoodshop.com/Furniture/FittingTheLidHinges.html
The clamps were removed for the photo ...
That is fine work, by the way.
hinge installation depth
I don't have any experience with the hinge you used. For a traditional barrel hinge I used a traditional approach of burying the barrel nearly half way into the frame so as to expose as little of it as possible. The less I see of a hinge the better. Ideally I would have used knife hinges but I thought the door was too tall for them with no support in the door middle.
Someone in the club uses another approach. He installs the hinge into an angled mortise to achieve a different alignment of the barrel with the crack. It strikes me as a lot of work for no benefit other than to set his work apart. I fret about getting near perfect installation anyway without making it more complicated.
Bill, that's beautiful work,
Eddie Vicarious in Northern AL
and I look forward to seeing it when completed. I've no doubt that the inlaid back makes the case as solid as can be. Nice!
Questions -- probably illustrating that I haven't been around much lately -- on the glass: Are your pieces rectangular or curved along the top edge? How are they retained? Are they sitting in a groove at bottom?
Thanks again,
Eddie
reply
Thank you. It has been years in the thought design phase. I am relieved to see it near done.
I haven't discussed the glass yet. The glass will set in a rebatet on the inside of the frame and be the shape of the frame you see. I have been to the glass cutter and he told me there would be no problem cutting the glass to shape. I will take the doors to him as well as a pattern for the sides. It will be held in with a strip of wood nailed with brass escutcheon(sp?) pins. The brass heads of these pins/nails provide a tidy look to the inside of the frame.
Sounds elegant.  Can't wait!
Wiley Horne--So. Calif.
Hi Bill,
I too am looking forward to seeing this beuatiful design realized. Will have more questions then, but for right now,
1. What are the overall dimensions?
2. Can any glass shop make those curves, or did you find someone particularly skilled?
Wiley
What are the overall dimensions? about 5' tall, 32"wide
2. Can any glass shop make those curves, yes but we have one shop in town that is difficult to deal with. I didn't go there because others told me they didn't do a job like this one.
