A Treatise of Japanning and Varnishing (1688)
Simon St.Laurent - Dryden, NY
Folks seemed interested last time I posted on this, and your encouragement made it easier for me to finish typing in the whole thing.
http://toolbytool.org/resources/StalkerParker.txt
I'll be proofreading it next, and then creating a prettier HTML (and maybe PDF) version. Here's a small sample.
To make common Lacker.
Take one quart of Spirit, put it into a Pottle-bottle; of Shell-
Lacc eight ounces, beaten small enough to enter the bottle; shake
'em well together; having stood till quite dissolved, strain it, and
reduce to powder a small quantity of Sanguis Draconis, which with
a little Turmerick tied up in a rag put into it, grant it a days con-
tinuance in that posture, at your leisure hours shaking it. You may
alter the colour, heighten or abate it, by adding or diminishing the
quantity of the two latter ingredients.
Enjoy, and thank you,
Simon
Re: A Treatise of Japanning and Varnishing (1688)
I think Yoda wrote the original, he did :)
A fun read. Glad I have General Finishes to do this work for me.
where can I get a pottle bottle?
Bruce, a MN Galoot
That was fun. Thanks!
John Aniano in Central NJ
Hello Simon,
Stalker/Parker appears to be adding Dragon's blood resin to his shellac, probably as much for color than for its resin's properties. Maybe the turmeric was there to add a yellow color. I didn't know the latter was alcohol soluble. Certainly a potent dye in water!
Have you ever read the works by Theophilus (~1125 AD) or Cennini (~1400 AD)? Similar stuff but quite a bit earlier. Both reprinted by Dover Books.
As usual, fun stuff. Thanks for doing the "translation"!
John
What exactly is a "pottle-bottle"?...
Hi Bruce, et. al.,
I, too, was curious what a"pottle-bottle" was. According to Merriam-Webster, a "pottle" is a noun meaning a half gallon container, and "bottle" a noun meaning a narrow mouthed container. Thus, a pottle-bottle is a narrow mouthed, half gallon container. Note that Stalker/Parker's instructions say to break up the resins to fit into the bottle, so they intended a narrow mouthed container. Also breaking up the resins helps them dissolve.
John
