ADVERTISE HERE - FREE TRIAL
no leg/front vice? no problem
Joseph Piotrowski
2 benchdogs and a holdfast ( picture listening to Beck, where it at) i'm twisted :)
my el cheapo bench has no leg vice or front vice. i need to rig up one to really make it useful but a quick and dirty solution seams to work fine for some 4/4 wood.
i drilled a dog hole in the end vice and in the apron. i then added a dog hole for a holdfast in the supporting leg.
overall i was able to plane without the board slipping. this should hold up until i manufacture a better solution or better bench!
just over sharing :)
Re: no leg/front vice? no problem
That's solving problems! Good work!
If you look at some of the primitive benches on which people in other parts of the world do production-grade work, you realize that solutions are always at hand; we just need to think outside the buy-the-solution box.
When you do build a better bench, or modify this one to meet your needs, you'll find, from this experimentation, that you know much, much better what you want.
Joseph Piotrowski
thanks Bill.
every step along the way from measuring to finishing is and will be a huge learning experience. in the information age one can sit back and over think every step of the process. research to no end. but all the gear before you make a cut.
but getting out there and cutting up wood is enlightening!
