THE WOODRAT IS BACK!
Frankenmooxon
Frankenmooxon
Frankenmooxon
Joseph Piotrowski
after the suggestion to make one of these, i went into my shop, rummaged around and found enough materials that i only need a carriage bolts and washers.
most of these stuff is like 15 years old laying around. if not longer
i found some 8/4 red oak, a 8/4 maple and a 4/4 piece of cherry. i had some old home made 3/8 wing nuts.
i didn't do much resizing. just cut to same length, squared up with some hand tools.
so i cobbled it tougher and even before complete finished i had to test it. i need to do a,little more finish work on it, like make nicer "wings" for clamps, some chamfering etc.
it held up just fine for what it is. i have much grander plans for a super duper one, eventually.
now i can dovetail in comfort!
Re: Frankenmooxon
Re: Frankenmooxon
AlanWS
Looks simple and effective. That's high praise.
One thing I know I prefer is when the bolts stick out in back rather than in front. The handles can be on the bolts, and the nuts attached to the back jaw.
Re: Frankenmooxon
I agree about bolts
Joseph Piotrowski
its definitely something i will consider in version 2.0
i'm sure i have some different hardware somewhere in my shop that will work like you suggest. i just can't find it all yet :)
i used 3/8 t-nut in the wing-nut. i can simply place t-nuts on the stationary face. this would allow shorter bolts. i use 8" bolts and that just to long. i probably cut them down.
