Veritas - Innovation in Tools
Drawer runner replacement options?
Joe in a Cleveland suburb
I am still working on bringing this old secretary back to life that I've shared some pictures of before.
The original runners are badly worn and falling off. They were simply (hide) glued into a dado across the case side. They were glued the entire length which probably lead to the case side splitting. They weren't/aren't attached to the front rail at all and there is no rear rail.
I was thinking of mortising the front rail to let in a tenon on a new runner, but I can't remove the front rail to mortise it.
I think I should glue the new runners in place and put glue in only the first couple of inches so the case sides can move.
I could put a rear rail in between the runners.
I've been trying really hard to do minimally invasive repairs to this piece.
Any suggestions on these drawer runners?
The below pics are shot up through the bottom of the case while it was lying on its back.
Thanks for any suggestions.
Pic 1
Pic 2
Pic 3
Re: Drawer runner replacement options?
It is common in Period furniture to see the runners simply nailed into the case side. Sounds crude but it works just fine for a few hundred years.
William Duffield
I don't have time today or this weekend to analyze your repair strategy, but I will point out one important point: If you examine old secretaries in museums, on ALL of them, the sides of the lower cases have split.
Wiley Horne--So. Calif.
Can everyone else see Joe's photos--they aren't rendering on my iMac w/Safari.
Thanks
Wiley
William Duffield
They render just fine on my iMac 10.11.6 El Capitan with Safari 10.0.3.
No photos
Re: No photos  NM
Here are the pictures...
Sorry... for years I have used Googles' Picasa service and easily linked to my pictures. Last year Google changed that service and it's no longer an easy task.
I used Ellis' method to resize my images and uploaded directly to WC.
Last night, after Bill and William's comments, I took another look at this. I think I am just going to replace the worn out runners and glue in new ones exactly like the originals and be done with it. I am over thinking this whole thing ...
Thanks for any more comments/suggestions.
Late to the party
Hi Joe and all,
When you install the new runners, would it be possible/practical to place a couple of glue blocks underneath each runner, up against the side panel. Perhaps one up front at the junction with the front rail, to provide alignment with the rail, plus support, then another at the rear for support, maybe another midway for good measure (though it probably wouldn't be necessary). The blocks could be short enough that they wouldn't create a cross-grain gluing problem, and they would also comport with your idea to just glue the first couple inches of the runners, if that is still what you're thinking. Hot hide glue has fast tack and would remove the need to clamp the glue blocks (which would be most difficult).
2 cents.
Wiley
Glue blocks. Good idea. Thanks.
