Re: Narex or PM-V11 mortise chisels
I need a new 1/4" Mortise chisel and I settled to choose between Narex and Veritas PM-V11. I do lots of mortises - no drilling here.
Did anyone get a chance to work with both of them? Over the long term, is the PM-V11 really worth almost 6 times more?
Hi Mihai
I was one of the testers for the Veritas mortise chisels before production (evaluating different handle sizes and A2 and PM-V11 versions).
Having for years used RI (in D2) and vintage Wards (in laminated steel), I would happily recommend either these types for chopping mortices. In design, these chisels are identical, only the steel composition changes. The D2 hold an edge longer, but the Wards will hold an edge long enough to complete several mortices. That's long enough.
I could say that holding an edge "long enough" is my definition of "good enough", but then we begin to throw in the woods we use, and how they differ in hardness. That is when our requirements for steel change.
It is only really possible for me to comment more equivocally about steels in the Veritas chisels. The Veritas mortices chisels I have arrived with a number of different handle sizes, which was one of the areas I needed to provide feedback about.
Through these distractions, it was apparent that these mortices chisels worked a little better than the English bolstered types. The blades are deeper at the bevel end of the blade, and this creates a little more registration.
I was very impressed with the A2 steel versions. In practice I could not tell which steel was actually better because they both held an edge so well that I ran out of time before they dulled. The point is, if one can afford the extra, get the PM-V11 (tests show they hold an edge very well), but the A2 chisels are darn good, so do not ignore them. They hold an edge long enough to be more than simply "good enough".
Comparing the Veritas to the Narex is difficult as I have not used the Narex. I don't like the look of their handles. Of all the handles, I prefer the oval bolstered types, but then I am also most used to them. The Veritas handles are directional, as are the Narex handles - both have flats on the sides - however, what is great about the oval handles is that they taper, and this enables one to find the ideal grip area. I cannot comment on the Veritas here as I have a variety of sizes, some large and some smaller. I do like the Veritas handles, nonetheless. They feel solid, and the chisels I used are very well balanced. At this time I prefer them to the oval bolstered types because the blades offer more bite and directional control.
What I would want to know about the Narex is whether the blades are tapered, as the Veritas and the traditional oval bolstered types are? The taper makes for easier release. Also, the Narex steel is likely to have less impact resistance than either A2 or PM-V11. The question is question is whether it remains good enough for your wood.
Narex ...
The Veritas primary bevel is ground at 25 degrees, compared to the RI and Wards at 20 degrees. All have a secondary of 35 degrees. The photo below was taken after I renewed the primary bevels of two Veritas chisels. The centre chisel is a RI ...
Below are the primary bevels of three 1/4" chisels: from top, Ward, RI, and Veritas. Note the extra depth of the Veritas. I also found that they levered chips better ...
Above: RI, Ward and Veritas. Note that this handle is a little wider than the production version. It feels more substantial than the impression from this photo as it is wider than the tapered handles. I recommended a reduction in diameter. I am sure others did as well, as that was the result.
