Shop in box
Shop in box
Shop in box
Joseph Piotrowski
box in a shop.
pop in shop
pop move shop
parents will understand that!
while setting up shop a realization has occurred. any new shop storage/cabinets should also support packing up and shipping to make my life easier later on. i may well be doing this 2 or more times in the next 4 years.
so any new wall mounted cabinets must meet be constructed in a way that will allow me to close it up and have it survive(with tools) the transport.
so far i have i have come up with the case will roughly be 18" wide, 24" tall and 16" deep. split in half to open up(clam shell?) so the mounted area will be roughly 36" wide x 24" tall by 8" deep.
i'll making these with mostly hand tools for the experience. construction of these with plywood and machine tools would be easier and quicker but i chose a different path with many things unknown, so maybe you all can help me solve them.
they are just going to be generic cabinets, no fancy wood or complexity(i'm saving that for later). they just need to be sturdy . i plan on making 2 to 4 of these. generically, one to hold cordless tools/batteries etc. 1 to hold all my sanding equipment and so on.
material: cost is a factor so maybe pine or poplar.
construction of the case is my first question. i'm thinking dovetailed side to top/bottom. or hand cut box joints. any suggestions will be welcome.
the biggest unknown is the back of the case so i'm open to ideas. I'm not sure of the material or construction.
material can be plywood if its the absolute best way. otherwise it would be solid wood. if its solid wood: panel glue up? ship lapped?
as for construction, is it enough to simple rabbit the back and secure with nails or screw? or would a slotted grove be better?
thanks,
Joe P.
Re: Shop in box
Re: Shop in box
For the kind of shipping crate/cabinet you're describing, I'd use 1/2" plywood for the back. I suppose best construction would call for rabbeting the sides of the cabinets, but you might be able to get by with lapping it over the sides and gluing and nailing it thoroughly. After all, regular shipping crates rarely use rabbets.
That will be less attractive where you can see the sides, so a rabbet has the advantage of a prettier cabinet.
Re: Shop in box
Re: Shop in box
Joseph Piotrowski
thanks. that a good idea to keep in mind. I'm not sure i care about seeing the side of the plywood. its shop stuff after all.
Re: Shop in box
Re: Shop in box
i'm thinking dovetailed side to top/bottom. YES to dovetails. It's the best joint and good practice.
"material can be plywood if its the absolute best way." Yes it is the best way. It is stiff and cheap.
"is it enough to simple rabbit the back and secure with nails " add some glue. I can't imagine not setting back in a rebate. 1/4" plywood is more than satisfactory with the case sides dovetailed. You don't want these units to be overly heavy.
Dovetailing is overkill, but I got proficient at dovetailing by practicing on things where a 0.002" gap didn't matter. (I'm poking some fun at dovetail standards here :) )
Re: Shop in box
Re: Shop in box
Joseph Piotrowski
.002" ?
i'm hoping I won't hear wind howling through them! lol.
thanks for the feed back.
Re: Shop in box
Re: Shop in box
On a serious note, I got proficient at doing dovetails by using them in situations where looks didn't matter. I thought of them as stress-free dovetails and I sawed them out with reckless abandon. When I made a 'Studio Furniture Grade" elevated base for wife's Victorio tomato juicer in 1" oak I knew I had nothing to fear from 1/2" poplar drawer sides. And by then I didn't give a damn what anyone thought of my dovetails so long as the drawer didn't fall apart.
Re: Shop in box
Re: Shop in box
Don Stephan
Costs a bit of internal space, and may have to use 1/2" plywood, but for multiple moves a french cleat hanging system may be helpful.
Re: Shop in box
french cleats? yes!
Joseph Piotrowski
that is a definite part of the plan. if not french cleat than some other type that will be external and permanent.
thanks.
