How It's Made -Particle Steels
We have had many discussions here about particle steel. While at the Midwest Tool Collectors meeting we got to meet the General Manager of Crucible Products (retired) who managed the furnaces. He likely made the CPM 3V we used to make our tools. He told us how particle steel is made.
Vanadium carbide provides wear resistance. But vanadium carbide crystals grow rapidly. If a vanadium alloy steel is simply cooled the vanadium carbide crystals will be too large (too coarse grained) to make a steel that will take a fine edge.
To make the particle steel a 3000 pound batch of alloy components are melted and forced through a small orifice. Orthogonal to the stream of molten metal exiting the hole are jets that direct a high velocity stream of nitrogen at the stream. The molten metal stream is broken up into streamers of molten metal that contract into spheres by surface tension. These micron sized spheres drop into a container of liquid nitrogen where they are quenched. The time scale for cooling is too short to enable large crystals of vanadium carbide to form.
In this doodle dust form the metal can not be fabricated. So, next this powder is sealed in a can, the can placed in a cannon barrel, and hit with 17,000 psi of pressure, which sinters the powder into a solid ingot which can be rolled into bars and sheets. No wonder it costs a bit more!
