Any of you hand tool guys ever make your own glue?
Keith Newton
I was out in the woods last weekend, when I came upon a pine tree which had been injured, that probably had about 1/2 gallon of hardened pitch hanging on the side. I was just imagining that if I'd been an early explorer, I'd probably want to harvest a little of it for something.
It could surly come in handy for starting a fire when things are really wet, and was used to seal holes and seams in boats. I even found a recipe for glue, by adding ashes from the fire to a melted batch.
Do any of you folks profess to be Woodsmen, and have other uses?
Re: Any of you hand tool guys ever make your own glue?
CJ in MPLS
The pitch would be more of a finish I think. The older glues that are a bit simpler to make result from boiling down bones and connective tissue, though the closest I get to this is making stock from turkey bones around the holidays.
Keith Newton
JL, My sister has taken to boiling the bones to make stock after the holidays too. Man, she is a good cook, and I'm always happy to put my feet under her table. For some reason, that made me think of Granny Clampett of Beverly Hills. I ought to go watch some reruns just to glean what I can from her vast depth of knowledge. ha, I think she would use rabbit skins. I'd use the tendons for cordage and lacing.
One thing I ought to do of Granny's which would be easy, since I have a Slippery Elm growing just outside my door, would be to harvest some of the roots, come Spring. They grow out in thick matts on top of the asphalt, so I can just pull them up without digging. The bark makes a fine tonic that heals everything according to her, and the strong thin fiber is already like thread or string for lacing.
Dang, As I'm sitting here thinking about it, what I need to do, is to start looking for the right tree, so I can try something I've wanted to do for a long long time, and that is to build a bark canoe. We don't have the right kind of birch down in my area, but I think I've read that If your willing to work at it, one can use a draw-knife and or other hand tools to cut away the deep furrowed part of other species like Hickory. Once you get it down to about 1/4" thick, it's supposed to be pretty tough, although I'll need to test that out first.
Yep, I'm going to have to start thinking about this project. This pitch may be the final piece to make it all authentic material. I've got a book around here someplace that I need to find and re-read. ha
I cut a huge hickory for fire wood. While drying bugs got under the bark and it peeled off the cut lengths of firewood whole. Bark makes exceptional coals for grilling and I save these large sections of bark for the winter fireplace grilling season.
Talk about tough! I can't break it. I have to chop strips to go in the fire. I think you could make a white water canoe from it. (pack a life jacket)
The folks I've met making their own glues and working with pine sap have been the medieval re-enactors of the Society for Creative Anachronism. Rawhide is an easy starting point for glue, and pine and other saps for varnishes and similar.
I haven't tried glue-making myself, but there are definitely folks out there doing it for small projects!
Thanks,
Simon
Thanks Simon, I haven't thought of those folks in a long time. I happened to run into some of them in a local park once about 15years ago. They were practicing for some special event. What fun!!! Those people have some serious toys, and are really into their hobby.
One thing I could do with this pitch, would be to make some torches. I was always intrigued in the movies, before there were flashlights, whenever there was a mob gathering to go after the bad guys, several guys would show up with something flammable wrapped around the end of a stick, burning bright. I'll have to make a couple to hang on the wall down at my cabin.
Hickory bark is a standard southern material for weaving chair seats. We have three chairs, made in Arkansas 45 years ago, with hickory bark seats, and they're showing no evidence of wear, even after two boys did their toddler/teenage best.
You have one of those things that other people covet:
http://aands.org/raisedheels/Techniques/coad.php
Coad is a sticky wax, and one of the things it is used for it attaching bristle, etc, ends to the sewing thread, these are used instead of needles, and they pass through much more efficiently. The holes are struck with an awl. These ends merely adhere, there is no knot, or eye.
I have a little sack of stone projectile points down at the cabin that Ive been planning to tie onto some handmade shafts. During hunting season, I've usually got a ready supply of sinew, and was thinking of melting some of this pitch to coat it, but this sounds like a better way to go, or should I say coad.
