Re: stanley 113 compass plane blades
Neal in SC
I have that plane. Since it is likely to go a long time between uses, I sharpened up the Stanley blade and use it. I couldn't justify spending money on an aftermarket blade for it. The stock blade works very well.
The problem you are likely to run into is that the mouth (on mine, anyway) is pretty tight. I can try tomorrow when I get back out to the shop, but I think any aftermarket blade worth considering may be too thick to work without enlarging the mouth. Since the mouth is in a pretty small piece of iron in a complicated assembly, I'd hesitate to do any modification.
I don't have any experience with Kunz blades, but I do have their scraper plane clone, and it is very low quality. I've seen posts that indicate their entire line is pretty low quality. I'd recommend you look at other options if you decide you really need to replace the blade.
HTH Neal
