Monitor the opening for the wires.
Gary Smyth
Wire bundles seem to grow. In my instance for a media cabinet I originally ran amplifier, tuner, equalizer, turntable, air fan, speaker wire (each numbered on its end). Some were heavier gauge and different lengths than the others. Over time to hide wires I added telephone charger, fax, printer cables off of a power strip located inside the cabinet. Then came the lighting, patch panel, wireless connections and cable router. What with the transformers for some of the electronics the back of the cabinet filled. The opening meant to hide the wires was too small. Part of the problem was that some cable lengths had to be "wire managed" and hung on the sides or rear or coiled. As long as there was no repair or new stuff added it worked. However, when something was replaced to pull the old plug/cable and put in new, the opening was progressively too small and the cables tangled. I was working out of the opening a bit larger than yours in the bottom third of the cabinet and had a full fifteen inches from the back of the cabinet to the rear of the original audio components, so I thought there was plenty of space. I was wrong. When I eventually build the new cabinet there will be an opening the full width of the compartment, and it will be wide enough to allow a transformer to slide nicely in or out with all of the other remaining wires connected. Let us know what your experience turns out to be.
