A bit of varnish furnace fun
Simon St.Laurent - Dryden, NY
Thanks to this forum, I found Stephen A. Shepherd's Shellac, Linseed Oil, & Paint - Traditional 19th Century Woodwork Finishes. One of the neat things in it was a varnish furnace, for working with ingredients that don't dissolve easily.
I tracked down his reference to Theoretical and practical treatise on the art of making and applying varnishes, Pierre-François Tingry, 1803, and typed the relevant section in French. As I don't (despite my name) speak French, I settled for Google Translate's version, which at least looks workable.
http://toolbytool.org/resources/furnace_English.html
I'll be working with a friend who's a potter over the summer to concoct one of these and try it out. Stephen's report in the book is intriguing, and hopefully I can work with and develop some recipes.
Has anyone tried this?
Thank you,
Simon St.Laurent
Very amateur finish explorer
Re: A bit of varnish furnace fun
Don't try this at home
...to quote the Mythbusters. What in fact the furnace is for, I think, is heating the varnish ingredients to chemically alter them and partially polymerize them into what we call varnish. At least this step is common to varnish preparation. I suspect this temperature is not far below the auto ignition temperature, since it must be high enough to break chemical bonds, ideally in a controlled way and not in an uncontrolled way, AKA fire.
You will undoubtedly make something, but how will you know it is a useful varnish? Can the raw materials for traditional varnish be had now days- Copal, amber, etc?
Re: Don't try this at home
Yes, the furnace is for modifying the resins, not for making varnish directly. (There are other things called varnish furnaces in commercial varnish production.)
Copal and amber and friends aren't on hardware store shelves, but they aren't hard to find:
http://shop.kremerpigments.com/en/mediums-binders-und-glues/solvent-soluble-binders/natural-resins/
There are cheaper places, but Kremer has a nice collection.
I will definitely be trying this outdoors!
Thanks,
Simon
and recipes still exist
There are plenty of older varnish recipes in that Tingry book and many others, as well as in modern guides for instrument makers, re-creators, etc.
A lot of them spend most of their time worrying about finding clean ingredients. That part at least seems somewhat easier now.
I'll know it's useful if it works, I guess!
Thanks,
Simon
keep a cookie sheet handy....
John in NM
best way to deal with a small oil fire is to put a bit of sheet metal over the container and remove the heat source.
Re: and recipes still exist
The first attribute that suggests success will be does it cure after application and how fast. Color will be obvious to assess as well as hardness, viscosity, and how well it levels. Less obvious will be adhesion, chemical stability, light stability, etc.
A lot of chemistry is going on during the "cook" and this chemistry is sensitive to variables the home made varnish maker doesn't have precise control over.
That said, I am interested in hearing about the results and hope they are favorable. I bought the last varnish I liked in 1970's. I understand Pratt and Lambert 38 is good but I have never found a source for it.
TomD
Pratt & Lambert 61 is a nice varnish, has the odd characteristic of making silk disappear, like glass cloth in epoxy resin. You can attach guides to your rod with silk, wet the silk out in 61 and the guides look like they are floating there. Many of the old products are no longer made, or something new is offered under the old name.
Somewhere in Stephen's blog
Chuck Nickerson
he link to a potter-friend who made some the Stephen's specifications.
I meant to buy one but never got around to it.
I guess I'll need to find some other way to inject unanticipated excitement into my life.
Re: Somewhere in Stephen's blog *LINK*
Bob Entwisle in NJ
Here's a link to Stephens blog post on the furnace, which contains a link to the potter who made them.
Bob in NJ
http://www.fullchisel.com/blog/?p=1180
