OT Warm steam vaporizer *LINK*
We dragged out the vaporizer today, after four (?) years in the bathroom, to see if it'll help with my chest congestion. This is a fairly recent model (see link below). After it sat, plugged in and with the indicator light on, for an hour, I was getting no noticeable steam from it, so I tried the pinch of salt additive to the water that they recommended. So far, nothing.
Should I be seeing steam, or is this, like so many other modern appliances, more modest in its output than the old vaporizers?
If I should be seeing steam, the next step is a vinegar soak, apparently.
https://www.vickshumidifiers.com/shop/humidifiers/vicks-warm-steam-vaporizer
Re: OT Warm steam vaporizer *LINK*
Wiley Horne--So. Calif.
Bill,
Years ago, I used one regularly for my wife, who was having breathing difficulties at that time.
I used different steamers, and they would all be making billows of steam after 5 minutes or so, as I recall. And this was using straight tap water. Now our tap water is probably more mineralized than yours, so salt might be needed in your case.
But here's the point I'm trying to get to....The one thing that would stop the action was when enough salt from the water had caked out onto the heating elements, that there was no more heat transfer happening. So I would pull the heating element and wash the salt off and out of it. I can't remember now if the elements were exposed to plain view, or if there was a shroud around the elements, but I could clearly see the salt caked up.
Suggestion: Check yours to see if there is salt caked from the last time you used it. And if there is not, I would add a tablespoon of salt to see if that makes a difference. For sure, though, mine would make plenty of steam in a matter of minutes. It always surprised me, how quickly it began producing.
Wiley
P. S. I just read your post again. If there is any salt clogging up the passage, the vinegar soak should fix it quickly. I think I would try that.
TomD
Is it a hot one or is the mist cool?
TomD
I suppose the time has passed when one can suggest a little more ironing? I bought a steamer/iron set-up last year that could cover a ground attack.
