Re: sharpening knickers
Wiley Horne--So. Calif.
Hi Joe,
I'll tell you how I have done it. And you don't have to do much forever, once you've set it up once. The double-nicker kind is what I have on dado planes. But single nickers tend to follow the same logic, since in many cases the flat outside edge is already pretty closely registered to either the plane side or the outer edge of the iron, as the case may be.
Anyways......as Wm. says, sharpen the inside rounded profile, leaving the outside alone, other than a lick to remove burr. To do the inside, I have done it two ways. First way is to use a slip stone, and just have at it, being careful to leave a rounded bottom on each nicker, and to keep the nickers the same length. Second way is to work each nicker along the edge of a regular square stone (I use water stones, but oil would work the same way), using a rolling action, the tilt of the iron to match the bevel of the nicker will make the 'off' nicker stand off the stone, preventing fouling.
Again, the main thing is to maintain the nicker's profile and above all, keep them the same length below the plane sole.
Wiley
