New WoodChat!
File Maintenance Idea
William Duffield
Today, I'm fitting restored, reglazed and repainted window sashes. the "new" part of the house is over 40 years old, and like lots of things in gGreenwich, was built from salvaged materials, so some adjustment is necessary. For some of it, I used a file, which I summarily clogged with wax, paint, primer and old wood. I don't like using a file card on the files I use for woodworking, because it dulls them, so I used my finger nail, and then another, and a thumb nail, etc. It soon became obvious that I had a lot more misfit windows than I had nails, so I started thinking about what I could use instead of the thumb nail. One of my snorkasauruses brought me the answer. She started with a tennis ball, but I knew that wasn't going to work, and tossed it. As usual, she brought it back several times, so I set it up. Then she brought me a cow hoof! Eureka!
Re: File Maintenance Idea
Interesting. Even though we're in dairy country here, I don't often find cow hoofs lying around; so you live in a resource-rich area.
Did you try chalking the file before using it? This has worked well for me in the past.
Bruce, a MN Galoot
I have the same feeling about file cards, so I use a brass brush. It worked really well. No snorkasauruses around, so no need for a cow's hoof.
William Duffield
"Cow Claws" are available at Tractor Supply, PetSmart, and probably in the pet aisle at your local supermarket. They're the same material as finger nails.
https://www.amazon.com/Natural-Cow-Hooves-Dogs-Pack/dp/B00KC681BW/ref=zg_bs_2975438011_1?_encoding=UTF8&psc=1&refRID=GVJN4HZKMV33AF1FDCJ1
They do have some disadvantages: After they've been chewed, they smell wonderful, like hot hide glue, and you wouldn't want to step on one barefoot in the middle of the night!
I use a brass brush on cheap files, but it still, albeit much more slowly than steel, dulls the files. And, yes, I've used chalk, but I hadn't brought a stick of it into the kitchen with me to do the final fitting on this window. The file I picked up in the shop is a 00 Heller half-round, so it is cut finer that the diameter of my brush's brass wire, and I have several files that are even finer. Paste wax, chalk and latex paint are difficult to extract with a brush.
I was taught....
Brian Roberts
a pretty slick little file cleaning trick.
A short length of copper pipe.....or tubing....whatever is handy...in an easy to hang onto length.
Pushing the copper across the file teeth (parallel to the teeth) will clean out whatever is stuck....and the teeth will quickly cut mating grooves in the end of the tubing so it actually works better as it "wears in".
The copper will not hurt the file teeth at all.
Really works....try it!
Joe Rogers Northern Virginia
Bill, I remember when you bought a bunch of stuff from Slav at the PATINA event years ago. He hasen't been back lately but I wonder if he has any tricks like copper or chalk to ease the use of coarse abrasive metals?
Joe
William Duffield
I never thought to ask him when I ran into him, but he always had something abrasive with which he separated me from my money. He is a wealth of unique file and rasp information, and carries an incredibly diverse supply of NOS products. He attended Handworks last year, and will be attending next year (May 19~20, 2017) as well.
Re: I Will!
William Duffield
That makes a lot of sense.
But don't use Aluminum EMT instead of copper. :D Aluminum has a real bad habit of clogging file teeth. Slav (ref. Joe's post) carries files especially made for filing Aluminum that work well on wood, too.
Re: I was taught....
Hank Knight
Brass works too. I have some brass bar stock I use to clean files. Like Brian says, push it across the file parallel to the teeth. It's soft enough to get down inside the grooves and push out whatever's in there. It's way softer than the file teeth, so it does not damage or dull them.
Brass comes in different tempers
Soft-tempered brass would probably work best.
a simple piece of...
Brian Roberts
scrap copper pipe or tubing....hard or soft....cheap and easy.
Re: My file cleaning regimen... *LINK*
John Aniano in Central NJ
Hello William, Hank and Brian,
I use files all the time in my bow making work and try to take proper care of them. I routinely use the following methods to clean files, in order of severity:
- swipe/rub file on my shop smock or pants leg
- soft horsehair bristle brush
- horsehair brush with VERY short (~1/8") bristles. I make these up myself with binding twine and have my barber use his electric hair clippers to make the ends flat and even.
- brass suede (leather) brush
- special, short bristle, brass brush made to clean files - I got them from a jewelry supply place - they are made in Germany. I've included the link to a vendor I gotten these from. I also get many of my files from them as well as MSC and Slav "the file guy"...
- piece of thin endgrain maple used as described by Brian
- soft steel nail head banged flat and filed to a wedge shape. This acts just as Brian's piece of copper (or brass) but has a more aggressive action. This soft steel tool will not only remove swarf but can even remove rust from file teeth. You can rejuvenate a somewhat rusted file to passable/good working condition.
- finally when all else fails, I use a small steel pick to remove individual bits of clogged material.
For the most part, I use the short horsehair bristle brush, the suede brush and the German brass bristle brush. They are always within reach on my bench top.
I NEVER use the steel wire brush side of a commercial file card. The steel wires are much too hard and can dull file teeth.
Over and out,
John
Brass file brush
I have a couple of those.....
Brian Roberts
brushes shown in your link.
Got them when in violin repair school in Red Wing.....ages ago.
They work well too.....if a little spendy.
I did final wick a little thin super glue into the center of them (small drilled hole)
because the bristles tend to migrate to the end opposite the one in use.....the glue locks them in place.
Don't worry if you get too much glue in there...soak overnight in acetone and re-glue more conservatively.
anneal it...
John in NM
Heat up red with a propane torch and quench in vinegar or water. Even let it air cool if you like, it'll just look a bit ugly.
Thanks Everyone
don stephan
What an extremely helpful discussion!!! Until now I've always used a file card. when using a piece of copper pipe, does one smash the end flat (wider contact area), hold the copper in a vise and push the file across the end, or hold the file on the table and push the copper across?
Re: Thanks Everyone
Hi Don,
As Brian indicated, push the copper (or brass, thin wood, cow hoof, soft steel, etc.) across the width of the file following the furrows made by the teeth - i.e. parallel to the teeth as he said. The file teeth will cut mating grooves in the softer material being pushed and these grooves push out the clogged material stuck in the teeth.
I just hold the file on the bench top and push the cleaning tool across it. Several passes will deepen the grooves in the softer piece as you go over the file. As Brian said, as it "wears in", and the grooves deepen, the cleaning tool works better.
John
William Duffield
After looking at your Otto Frei brush, I had another idea: a 3" or 4" length of heavy braided insulated copper wire (e.g., battery cable) would do the same job, especially if stabilized with glue as Brian suggests. You could even drill a hole in the center of the insulation and inject epoxy, or TB-III, or hide glue (made from your cow hoof :D) with a syringe.
Re: I Will!
Alexander Grigoriev
When you need to file or drill aluminum, use liquid soap as a lubricant. It will prevent aluminum shavings from sticking. Oil, though, may facilitate sticking.
When metal is cut, the fresh ("native") surface lacks any oxide and can be very easily stuck back to another fresh surface. Oil keeps aluminum from oxidizing. Water-based lubricants will instantly form a layer of aluminum hydroxide.
Love this site!
Don Orr
What an interesting and educational thread. A whole bunch of "I didn't know that before" here. Thanks!
Re: The Dogs Ate My Homework!
William Duffield
I was planning to go back out to the shop tonight after the chat to do some experimentation with file cleaning, specifically to try to shape the cow hoof and attach a comfortable handle to it. After ignoring it for months, not even leaving it where we would step on it barefoot in the dark, this evening they ate it. Back to the drawing board.
Tomorrow, I'm going to try putting a bundle of annealed copper bonsai wire into a piece of copper pipe and epoxying it into a turned wooden handle. We're mixing up several small batches of West System (205 hardener, of course) to assemble presents, and should have a ready supply available.
Re: Great system for small batches
TomD
are o-ring syringes. Drill a 1/8" hole in any top, like old plastic screw top pop bottles, fill with epoxy and yo can measure accurate batches, and the o-ring syringes last a very long time. Sam system can be used for stuff like cleaning products or mouthwash.
http://www.ebay.com/itm/Hand-Feeding-or-Medication-Syringe-5cc-/250670289105?hash=item3a5d1d10d1:m:mQeAcC-k-C83rpbUy6TjXKw
William Duffield
I have a big box of syringes like that, and do use them sometimes for dispensing epoxy, but in those cases, I treat them as single use. I've tried reusing them, but the acetone I use to clean out the epoxy ruins the o-ring. I still use them because they're inexpensive and because the needles are reusable after being cleaned with acetone, but syringes aren't.
Are you suggesting using them to dispense and measure individual quantities of resin and hardener, and mixing them later? I think that should work, but haven't tried it yet. So far, I've done OK with Lee Valley measuring cups or gram scales.
You really are making it.....
Brian Roberts
WAY too difficult!.....lol
Just use the copper pipe as suggested.....
