New WoodChat!
Wood moulding plane
Wood moulding plane
Wood moulding plane
Ken Martin
At a recent swap meet I got three wood moulding planes. Two are for tongue and groove however the wood wedge was stuck and couldn't be removed. I have managed to remove one but the other is stuck tight. Any suggestions on removing it?
Ken Martin
Re: Wood moulding plane
Not sure about this, but you might try wrapping them in plastic and putting them in the freezer for a day.
Wiley Horne--So. Calif.
Try tapping the iron from the top (the shank end) such that it passes down through the mouth of the plane and out. Don't wail on it, just some firm taps to see if you can budge it. If you can tap the iron through the bottom, then that will make some up-and-down wiggle room for the wedge and you may be able to work it free.
Wiley
Thanks
Ken Martin
Thanks to both Bill and Wiley. I tried Wiley's method, managed to drive the cutter out, then tapped the wedge and managed pull it out. Now to clean and sharpen the cutters.
Ken
