New WoodChat!
Marking Gauge Pin?
Marking Gauge Pin?
Marking Gauge Pin?
tom
I would like to convert my current gauge from a blade type to a pin type. Wondering what to use for a pin?
Thanks!
Re: Marking Gauge Pin?
Drill bit shank
William Duffield
You only have one? Why not start from scratch instead of potentially messing up the one you have, and make a few while you are at it? You probably need some of each for any moderately complicated project.
tom
Good idea! Now I will search out a plan. Or has anyone a suggestion?
The latest Popular Woodworking has an article with a really clever mortise gauge design. It's built with a wedge to lock it, but you could use another locking technique. What I liked about it was the simple sliding adjustment for the mortise width.
If you're looking to make a marking gauge, there's really not much to them: a stick the right length (the beam) and a block of wood (the head) with a hole, carefully made dead vertical to the face of the block of wood and the shape of the stick (plus, if you're using a locking wedge, space for the wedge).
A number of ways to lock them down. The wedge shown in the Popular Woodworking article is one. If you're using maple for the head, you can tap it directly for a thumbscrew, but put something under the thumbscrew so you don't mark the wood beam. Stanley had little cast brass jobbies, but you could just use a piece of thick sheet metal bent up at the ends so it won't get lost, with a little extra room allowed in the hole for it to be in.
A few years ago, I picked up a Stanley 64-1/2 marking gauge, distinguished by an oval head (the block of wood part). The face that registers against the wood is flat, of course; but gripping the oval shape is a lot more comfortable than gripping the standard rectangular head. Here's a pic of one, captured from the internet:
William Duffield
A very elegant and simple to execute mechanism for locking the head to the beam was elucidated by Frank Klausz many years ago. To find out more, search Google Images for "twist marking gauge" or "cam marking gauge". I think its best feature is that the locking mechanism doesn't require any metal parts and metal machining to minimize wear.
I'll extend an invitation to all and sundry that we get together this evening in the WoodCentral chat room to discuss the design and construction of shop made marking gauges. Hand tool chat usually starts about 9:30 p.m. Eastern Standard Time, almost 13 hours from now.
Tom, with your interest in Japanese designs, you could build this one, which I referred to as East-meets-West. Based on a Kinshiro ...
You can see the beam locking mechanism here ...
Construction details: http://www.inthewoodshop.com/ShopMadeTools/CuttingGauges.html
William Duffield
Three links revealed in last night's chat:
http://tinyurl.com/zyvstp3
There's no good reason you have to make the fence octagonal on this one. If you find the shape of Derek's fence more comfortable, by all means, adapt it. The only critical parameters are that the front face of the fence is flat, that the beam locks securely and doesn't wiggle, and that the cutting edge of the pin or knife is parallel to the face of the fence.
https://logancabinetshoppe.wordpress.com/2010/11/19/episode-29/
http://www.popularwoodworking.com/articleindex/mystery_of_the_marking_gauge
If you need specs of the gauge in the Seaton tool chest referenced in the Popular Woodworking article, I can probably find my copy of the book and send you the particulars.
