Stropping
Joe in a Cleveland suburb
Questions for those of you who use a strop as part of your sharpening...
Do you use a strop on both chisels and plane irons?
Do you worry about rounding over the edge?
How is your strop made?
Leather on piece of wood?
Do you use the rough or smooth side of the leather? Both?
What do you charge the strop with?
Do you have different strops charged with different compounds?
How do you use your strop(s) for chisels and irons-what is the technique?
Do you strop both sides of the iron/chisel?
Years ago I read here at WC about using the green compound on a flat piece of hard maple. I've done that occasionally and it seems to make a little difference. I recently got a piece of leather and was thinking about making a strop or two and wanted to know what you guys have to say about strops and about using them.
By the way, I have one of those green compound stick things I've used. I also have white compound in a tube that is used on the buffing wheel of a grinder. Can this white stuff be used on a strop.
White vs green. Is one more aggressive than the other.
Thanks!
PS, I hope this isn't one of those pins first, tails first kinda a questions...
