New WoodChat!
Drilling a saw plate question
I may have to enlarge the hole in the plate of an old saw in order to accommodate the size saw nut I can buy. Directions various places call for drilling the hardened steel with a carbide drill, which I don't own. Question:
Would it work to simply heat (more or less?) the spot with a micro-sized torch, then cool this spot by some means? The idea is to anneal the metal so that it could be drilled with any metal drill bit. If this idea has merit how much to heat and how to cool to result in a softened spot?
Saw kits are only $50-60. finished saws are 4-5 times this price. How much time does it take to convert a kit to a serviceable saw, not presentation grade? It looks straightforward to someone that has never done it. I tend to be optimistic to a fault. :)
Re: Drilling a saw plate question
Mike Jurnigan in Zuni
Bill,
If you have a Dremel type tool why not enlarge the hole with a burr or a stone?
Mike
That is what I'd try too...
John in NM
Or if the hole needed to be much bigger, perhaps I'd re-grind a cobalt bit to do the job (I like a grind similar to a brad point spur bit for sheet metal).
Re: That is what I'd try too...
Walter Barbier
I tried a Milwaukee Cobalt Red Helix bit on an old Disston saw that I picked up. Don't know the age of the saw but it was pretty well sharpened to a nub. The bit worked fine. Used a low speed on the drill and it cur right through, left a clean hole.
Warren in Lancaster, PA
Saw plates are deliberately tempered enough that we can file them. You ought to be able to enlarge the hole with a file without more tempering. I have also drilled saw plates with twist bits, which are considerably harder.
Hi Bill
Either enlarge the existing holes with a round chainsaw file, or drill out with a carbide drill bit. An example of the latter is below ..
I like the file idea
The saw has one missing screw which makes the handle a bit wiggly, and hence annoying, but I have endured it for several years.
There are some things where proceeding slowly ensures success. I can drill out the wood to the correct diameter, remount the handle and use the wood hole as a filing guide. Sounds like a plan.
I do have cobalt drills but I have experienced
catching" issues when enlarging holes in sheet metal with twist bits.
Re: I like the file idea
TomD
If you clamp the saw plate so it can't move you should be able to drill it, at least you won't need to have your hands on it, but it will drill. Mount the saw so if it does catch the teeth are trailing. Never underestimate the awesome force of a drill press.
Carbide bits in small sizes are very cheap and available on ebay, though you don't need them.
Your idea with the torch should work fine, but refinements to that strategy are to use your torch to heat a rod red hot, or at least 900 degrees, then force that against the plate, this precisely centers the heat. For small hole an approach used would be to put a nail or rod in a drill press and spin it will quill down force, this friction aneals the area to be drilled, though where there is already a hole, you would need a pilot. You can use the hot rod without the.
Probably the correct tool for the project is a chucking reamer, in small sized they are pretty cheap, they are at best able to enlarge about 1/16", though the actual cut depends on size. They are for fitting holes more than blowing them out. But they can do either. The come in 1thou increments, at places that have every tool. You can get major fractions in many places, and they often sell a 1 thou up size for slip fits. Try ebay, or victornet.com Or any of the large ind. supplies. They are quite useful for wood also.
http://www.victornet.com/subdepartments/Chucking-Reamers-to-3/8/1780.html
Paul in NJ
Hi Bill,
With a pre-punched saw plate, it takes me roughly 30 minutes for a rip and probably twice that for a cross cut. Finer tooth saws with more teeth take longer. Add 20 minutes to set the teeth. I am not a pro so I go slowly.
By far the most time spent is the handle. I recommend doing the slot for the plate, drilling the holes, and fitting the plate to the handle before investing time shaping.
Paul Dzioba
thank you
