Re: Won't save much time
Brian Holcombe
Thanks Warren! In chatting with a Japanese Tea House carpenter who apprenticed under another Japanese Tea House carpenter living and working in America he told me that the fellow did all joinery by hand and finished every surface by hand plane.
In doing so he could setup and cut the joinery for seven shoji panels before lunch. That may seem like a farce to anyone who needs to setup a table saw for every cut, but I can see how it is feasible, especially with an experienced maker who is not wasting time.
It is exhausting how many times people suggest using machine tools to me. I've yet to see where they are truly faster in joinery work.
I'm sure they are faster for production work, which is why they're used for it, but I'm not doing anything near production work so a 'run' for me is a few pieces or in this case a few panels.
Take the double tenon as an example, with jaguchi (mitered shoulder edge):
If one wants to break down the operations to machinable tasks that means setting up a saw for four separate cuts (and test cutting for each) to make the tenons. Followed by setting up a mortising machine to remove the waste between the two tenons, or cutting it out with 2-3 additional cuts on a table saw.
Then setting up a crosscut saw for the back, then setting up a tablesaw for the jaguchi.....and making certain that the shoulders all line up....which requires more test cutting.
I'll be long finished with those cuts by the time this all comes together.
