New WoodChat!
Have a question? Ask Woody!
Gawd - power toolz
Gawd - power toolz
Gawd - power toolz
I was backing out* two pieces of pine trim today, to fit it over a very lumpy wall around a built-in bookcase. I used a powered routah with a 3/4" bit, working outside in a light breeze. I had to get a drink of juice afterward. Even with the breeze, I needed to rinse out my throat.
But, alas, it was so much faster than the non-powered alternatives.
*Hollowing out the back of the trim between the edges where it contacts the bookcase and the wall.
Re: Gawd - power toolz
Bill, some jobs are more efficient with power tools. Horses for courses and all that.
I rarely use a router, but the ones I own have pretty good dust control (using a vaccum cleaner and wearing a good face mask) and I would say that this is preferred to working outdoors where the air/wind will move the dust all over the show. In suburbia, keeping the noise down is important if you do wish to remain friends with neighbours, so working indoors is the go.
Curious: what is your non-powered alternative
Ian Neuhaus
Mine would be a #40 scrub plane.
that is unless the trim was that awful paper covered MDF stuff
Re: Curious: what is your non-powered alternative
Yes, for hollowing as described, a scrub is good. Otherwise I would use a hollow spokeshave or a wide hollow plane.
Grunt-powered alternatives
Scrub would be one possibility. I've also found gouges helpful for this kind of work.
In this particular case, I'd have had to follow up the scrub or gouge with a rabbet plane of some kind, to clean out the corners; the bump in the wall goes right up to the bookcase.
I had to remove 3/16" (roughly 5mm, for folks who use metric measures) across most of the width of 3" boards five feet long - so a lot of material to move. So I hauled out the routah.
Re: Grunt-powered alternatives
Bruce, a MN Galoot
Routah for me, too. Sure, it can be done with scrub and rabbet planes, but at some point you want to be done with the project.
Re: Gutter Adze, Maybe?
TomD
I only use routers, and most wood power tools outside. My BS, jointer and planer are good. In Canada the way it breaks down is the not so posh neighbors, do woodwork. The posh ones are in constant renovation mode making way more noise than I ever do. I live in a low rise cottage homes neighbourhood that is set to be seriously upgraded. Eventually the smart people figured out that the shoreline exists somewhere other than in the downtown promenade. They are erecting 4 story modernist homes, right next to one story cottages. I may make an exception and finally get that 4x8 cnc router. Then I can start to make 4x8 placards of very disturbing scenes and study which ones cause curtains to close in the soon to be towers overlooking my yard. Scenes of sodomy I doubt would be effective. There is a good chance religious iconography of the non-satanic variety might work. Maybe a sign that thanks them for blocking the Gama rays from the power plant might work (the gamma rays just zip on through I believe, but being polite about people's efforts is always the best course of action).
Doing some smaller-scale backing today
Boy, this wall is irregular...but in the way that all sheetrocked walls are irregular - slanting in corners.
Needed to make space for the irregularities on the head casing, 4" or so on one end, 3" on the other. The gouge got me done in a trice, leaving a short section at the show end that I planed to fit the wall. The siding casings and additional trim bits to be added will hide all the gouge work.
What I'd try...
John in NM
A large hollowing plane - just the thing.
For a powered alternative, I've always done this with a skewed fence on the table saw.
Safety first
GolfSteve in Calgary
Router use requires a dust mask or dust collection, eye protection, and hearing protection....even for a quick job.
A glass of juice and a good hork onto the lawn isn't replacement for good personal protective equipment.
I'm guilty of occasionally using the mitre saw without hearing protection, because I've only got one quick cut and the ear-muffs are nowhere to be found, but the ringing in my ears isn't worth it.
Re: Safety first
William Duffield
There's a way to fix that hearing protection problem: First, go get a pair of earmuffs for each power tool that can cause hearing damage. Hang a pair over each tool's power switch. You have to pick them up (and put them on) before you can turn on the tool. When you turn off the tool, hang the earmuffs back over the power switch.
