New WoodChat!
Dado cuts
Dado cuts
Dado cuts
dewetha
Hi,
I'm working my back into woodworking after a long layoff. still cleaning the garage and making a space to call my own among all the other "stuff" we keep in there. this will be a long process and requires much work. so while i clean, unpack stuff and setup the power tools(they need a lot work) i want to look to build shop cabinets and other stuff to get the shop going again.
i'm turning to the dark side on my second time around. although i'll probably be a hybrid guy(i own an lot of power tools). i'm looking to replace my power tool techniques with hand tool methods.
i have very little in the way of hand tools so i will buy or even make the tools i need . those power tool can still be useful ;)
what i'm looking at is a way to make dado cuts for example , shelving and drawer runners. there may be ways to construct items without these joints that will be easier but i'd like to explore this joint with hand tools.
so my question for all of you is, what method and tools do you prefer to use to make this joint?
i looking forward to hearing form you all before i go off in the deep
Re: Dado cuts
Re: Dado cuts
AlanWS
There are plenty of methods:
1 A dado plane will cut them, frequently by following a batten held to your stock.
2. A pair of saw cuts to define the dado will allow most of the waste to be cleaned out by a chisel, followed if desired by a router plane to make the depth consistent.
3. A chisel does a good job by itself. I think this is a good way to start, since this uses the most readily sharpened tool, and encourages the skill most enabling for hand work.
Lots of videos are available showing the first two approaches.
The chisel-only approach is well illustrated in a video by The English Woodworker, though he calls it a housing. He also shows how to use a saw, and discusses the approaches. (Search youtube for Cutting The Housing / Dado Joint Without A Saw )
Re: Dado cuts
Jack Guzman from Maine
Re: Dado cuts
Dados are easy to do with a minimal tool set. When I was doing carpentry out of my truck I would have to cut a dado from time to time. I would score the sides of my dado with a knife along the edge of a square held to the line, then mark the depth on the ends. Then I would cut the scored lines to depth with a saw. Finally I would clean out the waste between lines with a chisel. Dado done.---Jack
Re: Dado cuts
Re: Dado cuts
dewetha, the most basic way to form a dado is to score the outer lines, saw to the depth you want, and use a chisel to zip out the waste. A refinement here is to use a router plane to level the floors. A variation of this is the sliding dovetail.
A slightly more advanced method is to use a dado plane. These have nickers on each side of the blade to prevent spelching. Vintage wooden dado planes are available fairly cheaply, alternately a modern HNT Gordon dado plane is just wonderful - and quick - to use.
HNT Gordon dado plane review: http://www.inthewoodshop.com/ToolReviews/HNTGordonDadoPlane.html
Re: Dado cuts
Re: Dado cuts
Joseph Piotrowski
thanks to all the people who responded!! it's been a loooong time since i have been active in woodworking, in the shop and online. it's refreshing to read the friendly help and advice that is still a presence on this board.
there seams to be a good consensus on the techniques so far. it's probably wise to learn all of them so that i have a good understanding of the joint and the tools to make it.
to Derek: i saw your blog last night and it seams that that plane is the boss of the dado joint! but for now it is a luxury item i need to invest in down the road.. i have bid on a few dado planes on ebay.
right now “My mind is a raging torrent, flooded with rivulets of thought cascading into a waterfall of creative alternatives.” i just need to kick the tires on the tired and true methods. because i have ideas ranging from a custom plane of my design. to utilizing the concept of a miter saw like contraption like on a Nobex proman mitersaw to guide a dado plane. but that is all down the road :)
Re: Dado cuts
Re: Dado cuts
William Duffield
This discussion would be incomplete if we did not discuss some of the disadvantages of the different methods. I'll start by pointing out that dado planes are fixed width, so the plane dictates the width of the dado, and thus the thickness of the board the dado will receive. Battens and saw, OTOH, can be set precisely from the shelf board itself.
The equivalent of this problem in the power tool world is the special width straight cutting bits that are matched (maybe) to specific plywood thicknesses.
Re: Dado cuts
Turn that disadvantage to an advantage
I was making a bunch of shelves for garage and shop from #2 common oak. I find adjusting the dado stack to get some precise width tedious. I thought, aha, I will just make 3/4" dadoes, more or less, and then stand the shelf board on end and run it through the saw with the distance between fence and blade 3/4". The result was a small shoulder on the end of each shelf(shelves were more or less 7/8 to 15/16". A delightful surprise awaited me. This shoulder provided substantial increase in the stiffness of the units. I now strive for a shoulder for all such dado joinery.
This discovery can be easily adapted to hand too construction. Personally I don't regard dado planes cheap. A set will be the price of a used Unisaw and one of the Gordon's planes will be almost that amount. So some means of multitasking their application is desirable.
Re: Dado cuts
Re: Turn that disadvantage to an advantage
Joseph Piotrowski
to me shoulders guarantee a good fit and it hides one side of the groove should tear out cross you path :).
i find certain techniques/ tools are better for one offs and others for production runs of mass quantities.
Re: Dado cuts
Re: Dado cuts
Ron Harper
Depends on my mood. Mostly I will use thr method Paul Sellersteaches gor housing joints mark one edge of tge housing chop slwn all along the lins. Offer board that will fit in housing scribe other edge chop down that side remove waste with chisel and router plane. I purposely ,ake this joint a little skinny and use a plane for a very tight fitting joint
Other times I use a dado plane
Re: Dado cuts
Re: Tool Purchase
Hank Knight
Dewetha,
If you decide your current need is an opportunity to add to your tool collection (always a good idea), buy a good router plane rather than a dado plane. A dado plane is a single use tool. It functions exceptionally well at cutting dados, but that's all it does. A router plane does a great job of removing waste and leveling the bottoms of sawn or chiseled dados, but it has many other uses, like cleaning up and centering tenon shoulders, and leveling uneven surfaces. I find all kinds of interesting uses for mine.
My $.02.
Hank
Re: Dado cuts
Re: Tool Purchase
Joseph Piotrowski
after much discussion,advice and research, looks like a router plane is certainly worth having. now i just need to figure out which one to buy!
thanks,
Joe P
Re: Dado cuts
agree and.....
get the Lee Valley as it is easy to adjust .
Re: Dado cuts
easy choice
The Lee Valley. Has tons of cutters available and it adjusts easily. I love mine.
Re: Dado cuts
Re: ditto
William Duffield
Extensive review of this excellent tool, here:
http://inthewoodshop.com/ToolReviews/The%20Veritas%20Router%20Plane.html
