working on a fun quiz. Ideas
justin ball
Do you know your tool?
A tool called a square tells you that your 90 degree joints actually are 90 degrees. But how do you know your square is square?
• Look at it
• Hope for the best
• Use a crisp, new, 50 GBP pound note against the fence and blade.
• Turn it over- correct. Hold the fence against the edge of a flat surface, draw a line. Flip the square and see if the blade remains parallel to the first line.
A brace is a type of drill. It is held firmly by the pommel, and the crank turned. It can drive the following:
• Spade bit- incorrect
• Auger bit
• Centre bit
• Spoon bit
• Screw driver bit
A 500mm piece of moulding in your historic home is missing and is a real eyesore.
• Pull down all the existing moulding so it’s all the same.
• Try and get a joinery shop to replicate the piece.
• Search boot sales for years to find the original pattern moulding plane that mad the original piece. You probably have to “fettle” the plane first.
• Find a suitable off cut of wood, a broken hack saw blade and get going! Correct- a moulding scraper for smaller jobs and be made from junk and do any shape you want to replicate.
In creating a through dovetail joint, do you cut the pins or tails first?
• Whichever you choose, both work, but half your woodworking buddies will hate you.
A mortice and tennon joint, in various forms, joins two pieces of wood. Which is the tennon and which is the mortice?
• I don’t know.
• This is a trick question
• I’ll ask Fred
• The answer is on the tip of my lounge. Correct. The mortice is the hole in which the tennon fits. Sort of like your Mouth and Tongue
How can you travel back 1500 years for about 40 GBP. Explain in full sentences, with reference.
• Answer: pic of Curragh in river, with link to Patrick project on redcoatphoto.com
