Making French Feet
I was reminded off line that I had failed to post the method used by the Headley shop.
Step one is to saw the kerf.
Step 2, critical, is to clamp a piece across the bottom of the kerf to prevent the kerf from becoming a fracture.
Step 3 is to prepare the wedge, saving the female cut=off shape for a clamping caul. The caul is wrapped in foil to prevent glue from sticking.
Apply front of foot.
Step 4, slather on the glue, tap in the wedge and clamp. When done corner block the inside.
