New WoodChat!
sharpening 1/8 inch chisel
Bruce Mack
I have a 1/8 inch Marples Sheffield chisel that I can't freehand sharpen to the same standard as other wider chisels, both Marples and 2 Cherries. I'm sure it's my inability to maintain registration of the narrow bevel on the stones. I could use my Veritas guide but I wonder if there is another tactic I could use?
Re: sharpening 1/8 inch chisel
TomD
I normally freehand them, not because I am so great, but because there is so little metal there that if you get a few lucky passes it comes up with an edge, particularly with things like Blue Chips.
You can increase the sense of registration by hollow grinding it. And by using hard stones like oil stones or ceramic Spyderco in my case.
You can place the bevel on the heel and window wiper the edge. In general work a small areas, this is not the place to try to work the whole stone surface evenly. I sometimes use the side of stones to stop wear.
Often it is the handle that outbalances things, and you might brace the chisel in one hand and thigh and move a small stone, like sharpening an axe with a stone where you bring the stone to the edge.
If all that has been tried, you could very easily make a tiny shooting set-up, a saw kerf intersecting a dado, and use a small stone like the hand plane. That way you could really put the stone to it.
Neal in SC
I use a Veritas Mk II with the narrow blade head to sharpen my 1/8 Lie Nielsen chisel, and it works very well. I have an old Eclipse jig, but it doesn't allow enough blade extension to sharpen at less than about 37 degrees. I used to have (well, I still have it, but I'd have to find it, LOL) a Veritas Mk I, but I gave up on using it on chisels as it was pretty easy to knock them out of registration and end up sharpening on a skew. For my money, the Mk II is the way to go.
Neal, hunkering down in South Carolina, waiting for Mathew.
Similarly to Tom, I freehand on a hollow grind.
The trick to honing a 1/8" chisel is to only pull the blade back, never try and push forward. Place the chisel at the far end of the stone, lock the wrists, and pull it back along the stone.
The small blade holder for the Veritas Mk II works well also, if you prefer a guide. Use the wide, straight wheel, if you have it.
Bruce Mack
Thank you all for many more ideas than I had. Try as I could, I could not get a planar bevel freehand. This morning I used an eclipse style holder and reworked the bevel with a diamond stone and a few grits of wet/dry sandpaper on a granite plate. It is sharp now. I must acknowledge that my freehand abilities are possibly mediocre even for much wider bevels, but still value the ease of refreshing an edge.
