New WoodChat!
A55 Smoothing Plane
Veritas Small Plow as a beader
Some months ago, Lee Valley released an upgrade for the Veritas Small Plow that included an improved depth stop and a modification to use the plow as a beading plane.
The modification involved the factory machining a bevel on the skate. I presume that this is to enable the skate to follow inside the path of the narrow land of the bead.
The update to the depth stop provides a reliable grip to its shaft. The original depth stop was apt to slip. Roughing the surface of the shaft helped. My response was to add a slot for a screwdriver, and tighten it up. As seen below, my knob still has the slot. Both plow bodies have the new depth stop ...
Lee Valley offered a inexpensive and fairly painless process for those wanting to upgrade their Plows - simply send the basic shell to the factory, and they would machine and return it. Out in the Antipodes, and other non-American lands, this process was not available as the higher shipping costs were a factor. Quite recently, Lee Valley came up with a solution for us, whereby they would simply send out a new, machined body shell to reduce shipping costs both ways.
I was undecided whether I would have the modification done. First of all, I prefer planes that do one thing and one thing well, rather than Swiss Army Knives. I already had a Stanley #45, and rarely use it (it is more interesting to look at). Besides, I have used the beading blades on the #45, and they are only successful on straight grained woods, preferably of the softer type.
Beading with the #45 on quarter grain Tasmanian Oak ..
The interlocked grain on the typical Australian hardwoods I work with are really unsuited to a plough-turned-beader. Then there was the set of beading planes I have recently restored for use - another reason why the Small Plow mod was not a good idea. At least they have a closed mouth to hold down the wood.
Most of all, I use scratch stocks and make my own cutters. And another old photo ..
However, I was curious, and so I sent off for the new, ubeaut, updated Small Plow, and ordered the beading blades (which are PM-V11 steel).
Plus, I had a cunning idea, a plan to make the Small Plow beader bead like no other beader could bead! Let me tell you about this ...
Step one was to test out the Plow on a scrap of Makore (left over from a recent build). I was interested to see what type of finish I could get using a slightly interlocked grain but one with grain that was mainly predictable.
Pop in a newly-sharpened 3/16" blade (they come 1/8", 3/16" and 1/4"). This is no different to set up than a standard plough blade. Planing with the grain, the finish was crisp and free of defects ..
Now I turned the board around and planed against the grain. The result was massive tearout, as expected ..
OK, so here is the plan: I would use a Stanley #45 beading blade of the same size as the guinea pig. This is identical in thickness to the Veritas blade, just longer. The extra length means that I cannot use the adjuster, and will need to set the depth of cut by hand. What will be different about this blade is that it will receive a 15 degree backbevel. That will create a 60 degree cutting angle! A high cutting angle of this magnitude no longer requires a mouth to control tearout.
Stanley on the left with the backbevel ...
So here we are planing into the grain with the Plow plus backbevelled blade ...
And the finish is pretty good! (alongside the bead you will see the tearout in the board that came from flattening it with a jack plane) ..
After satisfying myself that the backbevel was a Good Idea, the Veritas blade went the same route. This time I planed both ways ... both with- and against the grain.
The result was outstanding. It is difficult to tell which is which ...
In summing up, based on my small experiment, I think that the modification to the Small Plow looks like it will be worth the time and small cost ... if one also uses the blades with a backbevel. Of course, this advice extends to the #45 as well. The nice thing about this mod is that it is now really just a couple of extra blades. There is nothing to set up. I like it. Try it for yourself.
Re: Veritas Small Plow as a beader
William Duffield
Thanks for the back bevel tip, Derek. I was just using my plough with the beading blades for the first time Friday, but I only tried it on some red oak. There were plenty of tougher exotic species of hardwoods available, that would have "given it a run for its money" but I didn't try them. The oak had straight enough grain it worked fine in either direction.
I had a little trouble installing the depth stop with the new, improved clamp, since the factory installation of the clamp was not in perfect alignment, and I was away from the shop without an Allen wrench that fit. I started to adjust it with a diamond needle file, but quickly realized that wasn't the correct approach to the problem. I tapped the new clamp a few times with my plane hammer until I had rotated it a degree or two into alignment, and the shaft of the depth stop slid through.
Now, I need to figure out to what use I can put the old clamp and wavy washer. :)
There is, however, another solution to your problem: Since the small plough is made in both left handed and right handed versions, just buy one of each. :D I figured I should get the plough plane and their skew rabbet plane in left handed versions, since I'm left handed. This weekend, I found out that wasn't such a good idea. I was also using some moulding planes (hollows and rounds, etc.) that are right handed. Luckily I had installed FHWS stops at both ends of my sticking board. But, my sticking board is 8' long, configured for my bench at home, but I was working on a portable bench that was less than 4' long. Not a problem––I just cut the sticking board in two, but when I set down the rabbet plane and picked up a round, the stops on the other end had mysteriously disappeared.
