New WoodChat!
The Floating Credenza - Build Thread
Brian Holcombe
Good morning! I've started off a new build, creating a pair of wall hanging credenzas, one for media (TV) and the other for general storage. Both will featuring sliding doors, one will featuring drawers in addition to those sliding doors.
Please check out my post here;
https://brianholcombewoodworker.com/2016/09/26/the-floating-credenza/
I look forward to your comments.
Re: The Floating Credenza - Build Thread
Re: The Floating Credenza - Build Thread - OT...
John Aniano in Central NJ
Hi Brian,
A very thorough description and so clearly documented, as usual!
Did happen to notice in one photo, who in your household raises bonsai trees? I saw the training wire hanks, the specialized cutters, the nice copper watering can, etc.
I used to have ~25 small trees; I'm now down to one 25 year old dawn redwood and a 4 year old American elm in training.
John
Hank Knight
Thanks for this post, Brian. As John said, it is thorough and beautifully photographed. I'm looking forward to following along.
Your regimen for preparing long glue joints is very similar to mine, except you have a few extra steps. I don't use winding sticks to try the edge for twist. I get there by trial and error, balancing one board on the other and refining the edges until they meet solidly and completely along the entire length, and I check for square at numerous places along the edge as I go to make sure I don't get too far afield. I will give the winding sticks a try on my next build. Thanks for the tip.
Hank
Brian Holcombe
Thanks John!
I am the bonsai nut in this household, I keep after a few.
Brian Holcombe
Thanks Hank! Happy to help as always, let me know how it works out as opposed to tuning the boards one referencing against the other.
TomD
That is a long piece, and would probably get some kind of different treatment from me than the normal one I use. The normal one I use is to hollow the edge which allow me to use the plane sole as the measuring tool, then when I hit that point, I back it off with a set of snipes that I have a practiced way with. Normally that is it, but sometimes I goof it, and I have to try something else. If I am gluing up, I normally just pair the boards, I can hold 90 pretty readily, though again, I will shoot a bystander every now and then and have to make amends.
You work is wonderful. I am going to keep a careful eye on how it turns out. You production is pretty staggering. I am worried about the miters, I am not convinced that is going to look good, but we will see. If you have a particular challenge it is the integration of east and western themes which is a good thing and will allow you to develop a strong personal style, but some things may not work, or maybe they will. You have to try, once you get the call.
Brian Holcombe
I use your method as well, depends on the situation.
Thanks for your comments WRT design as well, it is tough to integrate them well enough and also separate oneself from the pack. It took 10 years but I think I finally developed my own style in case work with the Medicine cabinet and continued it through to the Butler's desk and these will follow along that same path.
I've made some work which is completely original along the way and some which I borrowed heavily and it's finally seeming to merge.
I've also made some mistakes in finding my own style, the original cabinet for instance I used long thin pieces of gaboon ebony for handles....they look great but won't allow the doors to fully open (you can only slide them until they bump into the opposing handle. Not a big enough deal for a do-over on something I live with, but for client work it is a non-starter.
TomD
Sounds familiar I always say if you are willing to do things incorrectly and fix them on number 2 you can be a designer. Of course some stuff comes out perfect the first time, other stuff does not, but if you are willing to take two shots at it, it is usually enough.
TomD
By the way, you present your experience modestly, it is good to know you have been at this at least 10 years. :)
Brian Holcombe
It sneaks up on you quickly doesn't it?
I agree, the second time you usually work out the remaining kinks. I make improvements where possible whenever I build something. The frames, for instance, I keep finding small ways to improve them...or I go to far and then reel myself back in.
