New WoodChat!
New Tool from LN
New Tool from LN
New Tool from LN
Don Orr
I had the good fortune to be in Maine last week and finally got to go to Lie-Nielsen and take the tour of the factory. In the assembly area they had a few samples of a totally new LN tool-the first and only examples so far. I was even given permission to take photos and post them. Tom has designed an updated version of the old Stanley 66 beading tool and yes he is calling it the LN 66. As you can see it has both straight and curved fences. No idea on price point yet.
I got out of the store with only a Boggs style curved bottom spoke shave and a 271 small router with depth stop. I also bought my wife a bench brush (she was with me and enjoyed the tour). We also met a very nice couple from New Zealand. He was like a kid in a candy shop and enjoyed himself a LOT. We gave them a few tips on places to visit as well.
I now have a much better understanding of the incredible quality that goes into LN tools and why they are truly a great value. Kudos to Tom and all his people for staying true to their integrity.
Re: New Tool from LN
William Duffield
Other than the matte black automotive paint on the ductile iron body, what's the difference between this one and the bronze one they've been producing for two decades?
Don Orr
They did not say.
It's on their website
Neal in SC
It's listed as available in limited quantities in powder coated ductile iron for $175.
TomD
Normally bronze is more expensive, slips better, has more weight, and is corrosion resistant. And it is pretty. The sewer pipe iron does not leap to mind as having any advantages other than that it works for the job.
William Duffield
I can think of one minor advantage, based on several years of experience with two different bronze L-N #66s. If you set it for an aggressive cut, the slot that controls the fences flexes just a little, but enough that the fence can move, sliding out of position. Since the ductile iron is stiffer, it should have less tendency to do that. However, the fence and the knob that secures the fence are still bronze and brass on the new model, and there is still the possibility that over tightening the knob can twist it off.
TomD
Thanks William, interesting. it is so easy to add stiffness with minimum bulk I would guess that as long as they designed each casting for it's material, or made if possible trivial changes that would allow either, it might be a go.
I just really like bronze, so maybe I oversell it.
Larry Barrett
I have this tool (the bronze version) and have had the problem you describe - the fence sliding out of position. I thought the fence knob was just not tightened enough so I added a small lock washer under the knob and sawed a slot into the knob so that it can be tightened with a screwdriver (I think Derek gets credit for that idea). It seems to solve the problem.
William Duffield
The guy I worked with twisted the post right off of the knob with a pair of Channelocks. I learned from his experience that it was a better idea to set it for a less aggressive cut, and advance the blade when necessary.
The Stanley that Lie-Nielsen based theirs on was cast iron, which is stiffer than bronze. I suspect L-N didn't compensate for the difference in strength in their original version.
