making a table
Some years ago I bought a piece of Moroccan marble with fossils in it. Finally, I am getting around to making a table from it. The table will live in the dining room by a window and have plants on it some of the time. I intend to make 4 legs and a skirt and simply set the table on this arrangement.
I just was not in the mood to set up the hollow chisel mortise so I chopped them out by hand.
I don't do hand mortises often so a crutch is useful to me. The crutch in this case is a pilot hole at each end of the mortise, drilled slightly under the mortise size. It provides both a depth gauge and chip clearance for starting the mortise.
I start at the near end a proceed away from me with the bevel away from me. Whack and pry. I ginned up some patience and found things went better by taking small, about 1/16 inch, cuts.
The first one proceeded awkwardly, but as usual by the time I was done I was getting proficient. The blue crayon mark was made to ensure the mortise was marked out on the correct face of the leg.
