Turned handle of Elaeagnus multiflora... *LINK*
John Aniano in Central NJ
Hi All,
Spent a bit of time the other day investigating a wood specie I was unfamiliar with, and wound up with a nice chisel handle in the process.
In private communications with Brian Holcombe on his descriptions of making a new genno hammer handle, he mentioned a wood called “gumi” which Brian said:
“Gumi is short for Natsugumi, its genus Elaeagnus multiflora. It’s also known as the silverberry tree. It’s very similar to boxwood but not exactly the same, it’s ‘the’ handle material for chisels, meaning it is the most prized, but not used for planes.”
My wife and I have a fruiting shrub in the backyard called a “sweet scarlet goumi” – I wondered if it was the same plant, which it was. Back in 2012 and 2013, I pruned a few large branches/trunks off our ~15 year old goumi bush, noted that the wood was hard and creamy colored, so, for curiosity sake, I had ripped the sections in half to facilitate drying, sealed the ends and then promptly forgot them…
After speaking with Brian, I looked back through my pile of wood scraps, found the goumi pieces and quickly noticed that some had spalted, primarily from the ends. Looked a bit like the bluish splotching that occurs in American holly but was brown streaks in the goumi. Two larger pieces had no splotching, so I gave one to Brian and kept the other. I have no idea what time during the year I cut these – in the future, I’ll have to take more care to prevent spalting by harvesting at the proper time and maybe with a spray of bleach before sealing the ends for drying. (Any tips or suggestions on this topic would be appreciated!)
As Brian had indicated, the non-spalted goumi looked remarkably like boxwood. It planed easily and left a nice finish. The growth rings were more widely spaced than is typical in boxwood since the latter is very slow growing by comparison to the goumi.
So, I made a traditional English turned/octagonal handle one might see on a tanged chisel. I know this is the hand tools side of things, but here goes anyway…
I used a brass 5/8” hex compression nut for the ferrule. I located the center points on the goumi blank and turned a short ~3/4” diam tenon at the butt end to hold the piece in a Beale ER collet. I used my South Bend metal lathe and it’s usual tool bit setup for the ferrule fitting portion of the turning shown here.
I turned the ferrule mounting tenon to ~0.025” over the ID of the threaded brass nut. Using a crescent wrench, I threaded the nut onto the tenon making sure there was no binding.
Then I mixed up some 5-minute epoxy, slathered it on both surfaces and used the wrench to fully seat the nut to the goumi blank.
After lunch, I set the blank back in the lathe, and using the compound rest, turned the hex facets off the brass nut forming a round ferrule. (This is easier to do in a metal lathe than by hand in a wood lathe.)
Then I set up a small hand turning rest and continued with regular lathe tools (gouges, skew and 3-point tool) to shape the handle. The wood was then sanded with 120 and 220 grit paper; the brass was sanded to 600 grit.
Off the lathe, I held the handle in my workbench leg vise and using a low angle block plane, planed off the facets to make a nice, slightly tapered octagon. Used 45 and 90 degree squares & calipers to ensure the facets were centered and tapered (0.5mm) as I wished. Then I cut off the waste and trued up the butt end.
In the images above, the larger of the two is the new goumi handle. The smaller is a commercial English handle of boxwood. See that the growth rings are much tighter on the boxwood vs. the goumi.
All in all, the wood worked very much like a slightly softer boxwood. I was able to dent the goumi with a boxwood piece, not the other way around, so seasoned boxwood is harder than the goumi I had harvested.
Elaeagnus angustifolia or Russian Olive, and Elaeagnus umbellate or Autumn Olive are both invasive plants here in central NJ. They have tasty reddish orange fruits that ripen in the late Fall and are in the same family as the goumi Elaeagnus multiflora wood I had turned. Perhaps, harvesting the wood of these invasive species might be able to “make lemonade out of lemons”. I’ll have to harvest some of these shrubs this Fall when their leaves have dropped.
Over and out.
Elaeagnus species overview
[/URL]
[/URL]
