Remembering tool alternatives
I'm installing trim on our auld haus remodel of the moment, and found myself having to back some of the trim - hollow it out behind, in the middle - to accommodate irregularities in the sheetrock finish. This was a fairly common practice when trim was 6-8" wide. The edges, after all, are the only "show" points on the trim (ends of head casings count as edges here).
I used a routah on one door's trim, but I hate the noise and dust. I then tried the scrub plane, which worked, but was a touch slow. Then I thought to get out a gouge*. Wow! Five minutes later, I had what I needed!
I need to remind myself that planes are not always the best solution to a problem.
*Carving gouge, because that's what was sharp. I really need to set aside a day for a sharpening fest, and get the several carpenter's gouges in my toolkit sharp.
