Where to buy Japan colors
My source of Japan colors doesn't stock any more. Anybody know a source? Mail order is fine.
Re: Where to buy Japan colors
William Duffield
What do you find to be the uses or advantages of Japan colors, as opposed to oil colors/colors in oil, or Mixol universal tints, or dry pigments? I've not used pigments that were specifically called "Japan".
Currently, I am using dry pigments, which can be mixed with BLO or varnish, and thinned with mineral spirits to make wood stains. Also, I can mix them directly with epoxy to make a colored wood filler, or with an oil based grain filler (e.g. Behlen's PoroPac).
I'm using Sennelier dry pigments that I order from Jerry's Artarama.
A popular brand of Japan colors is Ronan. A quick internet search shows several retailers who carry them.
thanks
a 3 life time supply for $30.
I use them to make oil stain. Maybe something would work better. I don't know because I never used anything else. Burnt Umber is all I use and I use it to color walnut.
Hank Knight
Most well stocked art supply houses will carry Japan colors. Google Dick Blick (really!) art supply and you'll get one of the very big supply houses. They should have Japan colors.
John in NM
I think our local Benjamin Moore dealer carries them. I noticed something like that a few years ago when I was looking for pigment to dye urethane resin for casting.
Re: Where to buy Japan colors *LINK*
John in NM
Yeah, the Ronan can looks like what it was. Only thing is the quantity was huge - a quart I think.
Link is where I found the pic, looks like a source of them too.
Japan colors
what I did, and some art conservation tidbits
The way I apply stain results in but a tiny usage. For example, the two bed side chests of drawers required only an ounce and a half of mixed stain that contained only 15 grams (teaspoon) of Japan color. The half pint of Moser Japan color I had would have lasted me forever. But a problem with Japan colors is that the remains in the can sets up to a rock after a few years of use.
I use Japan colors because they are mineral pigments and hence permanent in color. Most modern stains contain dye and who knows what they will fad to.
When I poked into the art supply world I found tubes of Burnt Umber pigment ground into linseed oil. I think this material will work. The squeeze tube should last for there is no oxygen exposure of the unused portion.
I took the lab tour at Winterthur. It was fascinating to learn how ceramic, furniture, fabric etc. was repaired and conserved. They were cleaning a painting by dabbing it with solvent soaked Q-tips. (the result was remarkable). I asked how that worked and the secret was linseed and similar drying oils.
The old timey oil painters used pigment ground in drying oil like I bought, which when dry is insoluble in everything. Then they cleverly over coated the painting with some protective coating that didn't cure into an insoluble film. I forget what they told me was used. Cleaning simply involves dissolving away the dirty over coat. The lady doing the explaining told me that modern painters often do not follow this procedure and as a result their work can not be easily cleaned when it is needed 200 years hence.
Re: thanks *LINK*
William Duffield
I have used Sheffield Bronze Colors in Oil, but after buying "3 life time supply" (half pint cans) and "3 life time supply in dog years" (quart cans), and having the linseed oil binder eventually turn to gum, I decided it made more sense to mix them as I needed them.
The advantage of these is that the pigments are very finely ground and thoroughly mixed with the oil. I can still dig to the bottom of the can and extract useful material for stain.
For walnut, I often add a little Van Dyke Brown to the Burnt Umber, and for mahogany, I add some burnt sienna to the burnt umber.
Sheffield Colors in Oil
Re: what I did, and some art conservation tidbits
William Duffield
The easiest way to find it in small quantities is to go to Michaels or A C Moore and buy their oil paint in tubes. Grumbacher is probably the best, but for hardwood furniture, just about any brand will do. For everything but burnt umber and maybe burnt sienna, one tube is probably a lifetime supply.
That overcoat...
John in NM
Usually a gum resin of some kind - dammar, copal, even pine resin. I once bought a jar of Canada balsam from a painter who was changing her technique. I wanted it for re-gluing old rifle scope lenses
Re: Linky
Hank Knight
http://www.dickblick.com/products/ronan-superfine-japan-colors/
Artists oils do last...
John in NM
I have some in lead tubes that belonged to my grandmother - she probably bought these in the 1950's or before. The caps are glued on tight by dried paint, but the tubes are still soft down in the body of it. Last time I used any was as a teen (surprisingly handy stuff for painting models) but for some reason I still have them around. I may cut one of the earthy colors open and experiment with your staining process
