Re: Will I need new sharpening gear?
david weaver
You won't need new sharpening gear. I'd say that the chisels you have not holding an edge is chance of one of two things:
1) the chisels just aren't very good
2) they could probably use an extra degree or two in bevel
I don't know your experience level, so I won't make a rude assertion that it's probably your technique - #2 above makes for a poor wearing chisel regardless of technique.
I've tested several chisels in a rockwell tester and since learned to use all but one of the chisels that I originally thought were too soft. They turn out to be my favorites now. Both in japanese and western, I like the chisels that are a step back from the hardest available.
I think #2 is worth trying with what you have, find the angle where they hold an edge well. If it gets too far past 30 (like into the 35 territory), then it's getting to where it's not an ideal bevel to use them and I'd look for something that holds up well at 30 or so.
